Distributor #67907
06/05/08 01:27 AM
06/05/08 01:27 AM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Chasing a non-spark problem on my 66 300, changed the electronic module tonight ran for awhile then died again. I'm assuming its the "relay" in the distributor;
By the way I converted to electronics to eliminate the points sytem.
Any directions folks can offer so I don't screw this up tomorrow/today. I've never torn into a distributor, so would like as much detail as possible.
Thanks in advance...........pun intended.
Re: Distributor [Re: Lugnutz] #67908
06/05/08 08:11 AM
06/05/08 08:11 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Really the only problem in the dizzy would be the gap between the reluctor and pick up (.008 with a brass feeler gauge).If necessary both can be easily removed. The relutor is pryed off and the pick up is held into place with screws (like points would be). Personally I think your ECU is the prob. good luck
Re: Distributor [Re: Kudakidd] #67909
06/05/08 10:39 AM
06/05/08 10:39 AM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Hey Kuda, thanks.....................I've replaced the ECU. That's what I thought it was as well. So I'm moving on to the next logical step. There is spark from the coil when you turn the key off and on, but none when you try to fire up the car.
Re: Distributor [Re: Lugnutz] #67910
06/05/08 02:30 PM
06/05/08 02:30 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
ECU grounded good?
won't work with out that
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Distributor [Re: Lugnutz] #67911
06/05/08 02:34 PM
06/05/08 02:34 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that makes me think on pick up coil damaged or its wiring.
Damaged ECU or fail on ground wouldn't produce anykind or spark at any moment ( as far I know )
Re: Distributor [Re: 65cuda] #67912
06/05/08 02:35 PM
06/05/08 02:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might want to replace the ballast resistor. If you have power with the key on but lose it in the start position that is usually the problem.
Re: Distributor [Re: stumpy] #67913
06/05/08 02:42 PM
06/05/08 02:42 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
thats easy to check... put the key in RUN and check for power at + lead of coil
Re: Distributor [Re: NachoRT74] #67914
06/06/08 09:42 AM
06/06/08 09:42 AM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Thanks for the respnses guys........it was the pick up in the distributor. Changed it and everything is fine now.
Re: Distributor [Re: Lugnutz] #67915
06/06/08 10:31 AM
06/06/08 10:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
that was what I thought!!! GREAT EVERYTHING IS FINE NOW!!!
