Re: 4 link question
[Re: B G Racing]
#678919
04/24/10 05:56 PM
04/24/10 05:56 PM
Posts: 415 Peru
cbarracuda
Peru
Good starting point is neutral preload and scale the car,you want 30 to 50pounds heaverier on the right rear tire.If your not turn the right upper bar one flat(nut adjuster) at a time for preload till you get the weight there.From there it's adjust as needed for handling and track conditions. I wouldn't make a bunch of adjustment based on one bad pass.If the car repeatedly drives right in either lane on multipal passes then add a little preload in the upper right bar as needed.
Thanks for the info I will borrow the scales and then put the driver inside and go for the 30 to 50 heavier on the right
Re: 4 link question
[Re: n20mstr]
#678921
04/24/10 06:30 PM
04/24/10 06:30 PM
Quicktree
you tune for track conditions with fornt and rear shocks and front travel
thats what I was thinking
Re: 4 link question
[Re: B G Racing]
#678923
04/24/10 08:58 PM
04/24/10 08:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
We tune with shocks for weight transfer,hook and hit.Driving right or left we use preload.
Re: 4 link question
[Re: MR_P_BODY]
#678924
04/24/10 10:07 PM
04/24/10 10:07 PM
Posts: 415 Peru
cbarracuda
Peru
Which of the holes will provide the best traction in a track with poor traction? I've set mine where the two x's are
Re: 4 link question
[Re: cbarracuda]
#678925
04/24/10 10:12 PM
04/24/10 10:12 PM
MR_P_BODY
LOL... your asking something that cant be answered with 2 Xs.... whats the IC length and height... weight of the car and HP... where's the CG
Re: 4 link question
[Re: MR_P_BODY]
#678926
04/24/10 10:22 PM
04/24/10 10:22 PM
Posts: 415 Peru
cbarracuda
Peru
Car weights 2700 lbs. with driver, HP around 700, wheel base 117". I can't answer the other two questions. The car is sitting low
Re: 4 link question
[Re: MR_P_BODY]
#678928
04/24/10 11:33 PM
04/24/10 11:33 PM
Posts: 415 Peru
cbarracuda
Peru
Plot out the holes and start about 45" out and 6" up ... you may need to move outward to about 55"... each car is some what trial and error but thats a starting point
It was already at 45 but it was low about 2 inches, so I'm going to try to move outwards at 55 and go 6 or 7 inches up thank you
Re: 4 link question
[Re: MR_P_BODY]
#678929
04/26/10 05:06 PM
04/26/10 05:06 PM
Posts: 415 Peru
cbarracuda
Peru
What do you think of this weight distribution: 56 front, 44 rear is it ok? or is it better to add weight to get 50 50?
Re: 4 link question
[Re: SCDaytona]
#678932
04/26/10 09:31 PM
04/26/10 09:31 PM
Posts: 415 Peru
cbarracuda
Peru
Are you sure you have 117" wheel base? If that is a stock wheelbase barracuda, I would bet it's not. I usually go 1/2 wheelbase about 3 inches high to start.
No, It's not for my Barracuda. I'm working on a 1953 Studebaker with 512 Mopar 727- 8 3/4
