Carter M6903 mechanical pump works great in most big-block street applications.
Here are the specs:
• 5.5 to 6.5 PSI
• 120 GPH flow rate
• Tough lightweight aluminum silver cast finish body
• Large full-flow valves
• Anti-float springs for high RPM operation
• Heat treated lever
• ¼” NPT inlet and outlet
• Housing is positioned for the many popular Chrysler O.E. fuel line routing but can also be rotated to accommodate different inlet and outlet locations
• Perfect for stock or modified Mopar muscle cars requiring additional fuel delivery while maintaining a stock appearance under the hood
These Super Mechanical Fuel Pumps are available exclusively from Mancini Racing and retail for $99.95 for M6903 units.
http://chucker54.stores.yahoo.net/cam6bisumefu.htmlThanks.
Mancini Racing
800-843-2821
www.manciniracing.com
