whats a good mech fuel pump for a BB #678835
04/24/10 12:32 PM
04/24/10 12:32 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
eng is a 1969 383hp stock... looking for a good quality FP
Re: whats a good mech fuel pump for a BB [Re: ngpSatellite] #678836
04/24/10 01:18 PM
04/24/10 01:18 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Stock replacement pump from your local parts store is more than adequate for a mild 383.
Holley and Edelbrock have nice (but expensive) upgrades. The Carter 6903 hemi style pump is an option as well.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: whats a good mech fuel pump for a BB [Re: ngpSatellite] #678837
04/24/10 01:42 PM
04/24/10 01:42 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
Stock is a very good choice.
I tried a HEMI fuel pump from Y1 on my 440. First the glass body Purolator fuel filter split length wise, then the pump casting cracked. Now I have a stock pump and a metal filter.
Re: whats a good mech fuel pump for a BB [Re: 74RALLYE] #678838
04/24/10 02:51 PM
04/24/10 02:51 PM
under the hood
A47 Offline
A47  Offline
under the hood
yes my hemi carter pump cracked also !! first couple of hundred miles ok , went in the garage one morning ,strong smell of gas !! cracked pump !!
Re: whats a good mech fuel pump for a BB [Re: A47] #678839
04/24/10 06:42 PM
04/24/10 06:42 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I run the Eddy on my 383 HP. Nice piece. USA made
I want my fair share
Re: whats a good mech fuel pump for a BB [Re: SomeCarGuy] #678840
04/24/10 07:14 PM
04/24/10 07:14 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Stock parts store pump will be fine. For a few bucks more check out mancini raceing. They have a few really nice pumps.
Re: whats a good mech fuel pump for a BB [Re: Dougsmopars] #678841
04/28/10 04:30 PM
04/28/10 04:30 PM
Detroit, MI.
Mancini Racing Offline
Detroit, MI.
Carter M6903 mechanical pump works great in most big-block street applications.
Here are the specs:
• 5.5 to 6.5 PSI
• 120 GPH flow rate
• Tough lightweight aluminum silver cast finish body
• Large full-flow valves
• Anti-float springs for high RPM operation
• Heat treated lever
• ¼” NPT inlet and outlet
• Housing is positioned for the many popular Chrysler O.E. fuel line routing but can also be rotated to accommodate different inlet and outlet locations
• Perfect for stock or modified Mopar muscle cars requiring additional fuel delivery while maintaining a stock appearance under the hood
These Super Mechanical Fuel Pumps are available exclusively from Mancini Racing and retail for $99.95 for M6903 units.
http://chucker54.stores.yahoo.net/cam6bisumefu.html
Thanks.
Mancini Racing
800-843-2821
www.manciniracing.com
