69 RR reverse lights mounting question... #678456
04/23/10 07:50 PM
04/23/10 07:50 PM
MA
440beeper Offline OP
MA
Not sure how the reverse lights mount to the rear bumper of a 69 Roadrunner... I'm assuming they use some sort of U-nut, but I'm not sure. Standard hardware store U-nut or are they a specialty item? Thanks
Re: 69 RR reverse lights mounting question... [Re: 440beeper] #678457
04/23/10 08:24 PM
04/23/10 08:24 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
yes on the back side of bumper is horse shoes shape plate that the screw go in
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 69 RR reverse lights mounting question... [Re: 1969gtx] #678458
04/23/10 09:02 PM
04/23/10 09:02 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It's a thin flat horseshoe shaped piece of stainless steel with a screw hole in the end of each leg of the "horseshoe". It's not a u or J nut type of hardware. It's a retainer plate. The opening in the horseshoe is the same radius as the opening in the bumper.
Re: 69 RR reverse lights mounting question... [Re: RoadRunnerJD] #678459
04/23/10 10:16 PM
04/23/10 10:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
theres a picture of what they look like here
https://board.moparts.org/ubbthreads/show...rue#Post5915684
