Blown motors and roller lifters.............
#678410
04/23/10 05:11 PM
04/23/10 05:11 PM
Thumperdart
State of confusion
A buddy om mine is building a BB Chevy(I know)for a local racer and was checking on different sites about the best lifter for that application and got several different opinions so I thaught I`d hit you guys up. He was curious about the new Red-Zones piece that uses a bushing instead of needle bearings also.........anyone have any hands-on experience or know of a lifter for this application? Thankxx guys...........
Re: Blown motors and roller lifters.............
[Re: Thumperdart]
#678414
04/23/10 06:18 PM
04/23/10 06:18 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Race or street and how much boost and RPMs?
[Re: Thumperdart]
#678416
04/23/10 08:20 PM
04/23/10 08:20 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Full on race car but I don`t have specs however, he`s going to check out my post later so maybe he`ll chime in.
Not cheap but Jesel keyways are the ONLY lifter that Jason will put in our Ford.
[Re: BobR]
#678417
04/23/10 09:37 PM
04/23/10 09:37 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I would think the bushing would be the way to go, a buddy of mine ,also big block chevy just broke a roller , needle bearings went through the pickup screen into the pump which locked up , then screwing the dizzy right off the intake. $$$$ Tear down, Replace cam, pump, gear on dizzy, heli coil intake , gaskets etc. Yeh, bushings. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: rowin4]
#678418
04/23/10 11:04 PM
04/23/10 11:04 PM
BobR
Left Coast
I would think the bushing would be the way to go, a buddy of mine ,also big block chevy just broke a roller , needle bearings went through the pickup screen into the pump which locked up , then screwing the dizzy right off the intake. $$$$ Tear down, Replace cam, pump, gear on dizzy, heli coil intake , gaskets etc. Yeh, bushings. ![](/ubbthreads/images/graemlins/popcrn.gif)
Good lifters don't do that. We have never had a lifter failure of any kind and we run a lot of cam, a lot of spring pressure and 9800 RPM.
[Re: BobR]
#678419
04/23/10 11:10 PM
04/23/10 11:10 PM
Posts: 705 Michigan
Hemiroid
Bob,
How many laps before the lifters get replaced? Not everyone can afford to change a $2500+ set of lifters every 30 laps.
[Re: BobR]
#678420
04/23/10 11:58 PM
04/23/10 11:58 PM
rowin4
He doesn't run cheep stuff and they were not that old. I think it was one of those freek deals. Just a tad under .800 lift and 7400 rpm's ![](/ubbthreads/images/graemlins/shruggy.gif)
![](/ubbthreads/images/graemlins/wrench.gif)
