{{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} FIXED }}}}}}}}}} #678376
04/23/10 04:42 PM
04/23/10 04:42 PM
Lehigh Acres, Florida
rickstershemi Offline OP
OK, my sons pickup...360...is leaking oil at the dizzy base, it's an aftermarket unit w/o-ring, oil pressure is 45# @ idle and 70# on the peddle...???? This is warmed up @ 180 - 190*
What do you guys think it could be....just a crap fit or something else, have never seen this situation..??????
Doesn't leak until it's run hard....?????
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678377
04/23/10 04:47 PM
04/23/10 04:47 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Is it a Mopar perf ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678378
04/23/10 05:19 PM
04/23/10 05:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve never had luck w/just the o-ring so I use the paper gasket around the base also......problem solved.
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: Thumperdart] #678379
04/23/10 05:33 PM
04/23/10 05:33 PM
Same thing I thought, just wasn't sure as the oil pressure being 50-75# seems unusual for a stock melling pump on a stock 360 long=block rebuild..???? Will have to grab some gaskets tomorrow and try-em out...
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: Thumperdart] #678380
04/23/10 05:35 PM
04/23/10 05:35 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
If it pukes out under load I would put a bigger PVC vent on it .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: go green] #678381
04/23/10 05:43 PM
04/23/10 05:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Even then it shouldn`t leak..........mine doesn`t w/or w/out a pvc valve.
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: go green] #678382
04/23/10 05:49 PM
04/23/10 05:49 PM
Excellent question....drivers side v/c is vented...pass v/c had a PVC, I removed the PVC since the d/s cover was vented....???? Would I be better off blocking off the vent and just running the PVC...??????
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678383
04/23/10 05:55 PM
04/23/10 05:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
For the pcv to properly work you need the valve on one side and breather on the other. It STILL shouldnt leak when you put the paper gasket on in my opinion.
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: Thumperdart] #678384
04/23/10 05:59 PM
04/23/10 05:59 PM
well we will give it try.....I was just surprised at the oil pressure and thought there could be a problem that I wasn't aware of....
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678385
04/23/10 06:03 PM
04/23/10 06:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rick the oil pressure doesnt have anything to do with
it, its just splash oil getting up there and getting
out... gotta have a O-ring or gasket... if its not
vented good enough that pressure is going to get out
WHERE EVER it can and right now you dont have a positive
seal at that point... get a gasket on it and check the
venting
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: MR_P_BODY] #678386
04/23/10 06:38 PM
04/23/10 06:38 PM
venting
Thanks Mike, kinda what I thought, it has a vent on the d/s and a PVC on the p/s and it was still leaking....so it must be the gasket, the o-ring on the dizzy is suspect as to location, it looked to be below the btm of the casting or very close
I will get a couple of gaskets and try that, should do the trick.... Wasn't sure on the oil pressure playing a part in it though, thanks for clearing that up
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678387
04/24/10 12:26 AM
04/24/10 12:26 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yo sure it is the distributor and not the intake or oil pressure sending unit, or gauge adapter?
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: Al_Alguire] #678388
04/24/10 12:42 AM
04/24/10 12:42 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
exactly what i was thinking
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: Al_Alguire] #678389
04/24/10 06:47 AM
04/24/10 06:47 AM
I'm fairly certain it is at the dizzy, I know it's not at the sending unit and hope it's not the intake If it still leaks after adding gaskets then it will be the intake
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678390
04/24/10 08:43 AM
04/24/10 08:43 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Another vote for the oil sender or intake manifold,as i,ve owned lots of mopars and never had a distributor leak.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: moparmxz] #678391
04/24/10 10:26 AM
04/24/10 10:26 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I was thinking rear intake gasket as well. May have lost its seal when you wasnt running the pcv valve.
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: 727builder] #678392
04/24/10 02:13 PM
04/24/10 02:13 PM
It was leaking before I disconnected the pvc...???? It looks to be coming from the dizzy, going to pull it today or tomorrow and try the gaskets on the dizzy...?????
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} [Re: rickstershemi] #678393
04/24/10 03:27 PM
04/24/10 03:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I guarantee you IF it`s the dizzy, that gasket will seal it......................been there done that.
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} FIXED }}}}}}}} [Re: Thumperdart] #678394
04/24/10 05:26 PM
04/24/10 05:26 PM
Well it looks like your the winner Dominic....it was the dizzy and I had a gasket for it in the kit that came with the long block never thought to use it do to the o-ring on the cheapo billet dizzy By the way I am very pleased with this distributor....$59 bucks delivered and so far it's a fairly nice piece
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} FIXED }}}}}}}} [Re: rickstershemi] #678395
04/24/10 05:35 PM
04/24/10 05:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to hear you got that out of the way
