Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}}
[Re: rickstershemi]
#678378
04/23/10 05:19 PM
04/23/10 05:19 PM
Thumperdart
State of confusion
I`ve never had luck w/just the o-ring so I use the paper gasket around the base also......problem solved.
[Re: Thumperdart]
#678379
04/23/10 05:33 PM
04/23/10 05:33 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Same thing I thought, just wasn't sure as the oil pressure being 50-75# seems unusual for a stock melling pump on a stock 360 long=block rebuild..???? Will have to grab some gaskets tomorrow and try-em out...
Rickster
[Re: go green]
#678382
04/23/10 05:49 PM
04/23/10 05:49 PM
rickstershemi
If it pukes out under load I would put a bigger PVC vent on it .
Excellent question....drivers side v/c is vented...pass v/c had a PVC, I removed the PVC since the d/s cover was vented....???? Would I be better off blocking off the vent and just running the PVC...??????
Rickster
[Re: rickstershemi]
#678383
04/23/10 05:55 PM
04/23/10 05:55 PM
Thumperdart
State of confusion
For the pcv to properly work you need the valve on one side and breather on the other. It STILL shouldnt leak when you put the paper gasket on in my opinion.
[Re: rickstershemi]
#678385
04/23/10 06:03 PM
04/23/10 06:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Rick the oil pressure doesnt have anything to do with it, its just splash oil getting up there and getting out... gotta have a O-ring or gasket... if its not vented good enough that pressure is going to get out WHERE EVER it can and right now you dont have a positive seal at that point... get a gasket on it and check the venting
[Re: MR_P_BODY]
#678386
04/23/10 06:38 PM
04/23/10 06:38 PM
rickstershemi
Thanks Mike, kinda what I thought, it has a vent on the d/s and a PVC on the p/s and it was still leaking....so it must be the gasket, the o-ring on the dizzy is suspect as to location, it looked to be below the btm of the casting or very close
I will get a couple of gaskets and try that, should do the trick.... Wasn't sure on the oil pressure playing a part in it though, thanks for clearing that up
Rickster
[Re: rickstershemi]
#678387
04/24/10 12:26 AM
04/24/10 12:26 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Yo sure it is the distributor and not the intake or oil pressure sending unit, or gauge adapter?
[Re: Al_Alguire]
#678389
04/24/10 06:47 AM
04/24/10 06:47 AM
rickstershemi
I'm fairly certain it is at the dizzy, I know it's not at the sending unit and hope it's not the intake If it still leaks after adding gaskets then it will be the intake
Rickster
[Re: 727builder]
#678392
04/24/10 02:13 PM
04/24/10 02:13 PM
rickstershemi
I was thinking rear intake gasket as well. May have lost its seal when you wasnt running the pcv valve.
It was leaking before I disconnected the pvc...???? It looks to be coming from the dizzy, going to pull it today or tomorrow and try the gaskets on the dizzy...?????
Rickster
Re: {{{{{{{{ OIL LEAK @ DIZZY }}}}}}}}} FIXED }}}}}}}}
[Re: Thumperdart]
#678394
04/24/10 05:26 PM
04/24/10 05:26 PM
rickstershemi
I guarantee you IF it`s the dizzy, that gasket will seal it......................been there done that.
Well it looks like your the winner Dominic....it was the dizzy and I had a gasket for it in the kit that came with the long block never thought to use it do to the o-ring on the cheapo billet dizzy By the way I am very pleased with this distributor....$59 bucks delivered and so far it's a fairly nice piece
[Re: rickstershemi]
#678395
04/24/10 05:35 PM
04/24/10 05:35 PM
MR_P_BODY
Glad to hear you got that out of the way
