Can you/do you run QTP tires tubeless???? #678152
04/23/10 12:27 PM
04/23/10 12:27 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
I just ordered my Quick time pro tires and was planing on running them tubeless.
can I ???
do you guys run tubes or do you run tubeless?
I just checked the price on tubes, like $67.00ea ouch
Re: Can you/do you run QTP tires tubeless???? [Re: Mopar Ron] #678153
04/23/10 12:37 PM
04/23/10 12:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Always have....just make sure the bead get a good slab of soap/sealer goo.
Re: Can you/do you run QTP tires tubeless???? [Re: Mopar Ron] #678154
04/23/10 12:38 PM
04/23/10 12:38 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Take it for what it's worth.........the guy I bought mine from ( used ) did just that.
I tend to side with the folks who designed the tires in deals like this.......I'd be getting tubes.
Re: Can you/do you run QTP tires tubeless???? [Re: tubtar] #678155
04/23/10 12:41 PM
04/23/10 12:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, I guess since I`ve been driving and racing w/these tires I don`t know what I`m talking about ESPECIALLY since I didn`t design em.
Re: Can you/do you run QTP tires tubeless???? [Re: tubtar] #678156
04/23/10 12:43 PM
04/23/10 12:43 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I have ran mine with no tubes but didnt realize I needed too. When I bought mine a few yrs ago,I dont think their website stated that I NEEDED to run tubes or I would have. Just looked at their site because I need to order some new ones and the site does say TOO use them. So I will with my next set.
Re: Can you/do you run QTP tires tubeless???? [Re: Thumperdart] #678157
04/23/10 12:46 PM
04/23/10 12:46 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run tubes in my QTPs
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Can you/do you run QTP tires tubeless???? [Re: MIKES_DUSTER] #678158
04/23/10 12:50 PM
04/23/10 12:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
THEY also say not to run spools on the street.......or 8" converters, or roller cams....get the point? Do what you need to do to make you feel better except now that $31.00 savings just went out the window...
Re: Can you/do you run QTP tires tubeless???? [Re: Thumperdart] #678159
04/23/10 01:34 PM
04/23/10 01:34 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
If tubes are simply to keep them aired up , que sera sera .........if they can prevent the " what if " , then it is 120.00 well spent.
I have heard of them losing air sitting , but that may have been a rim issue too
But since I am not an expert , I will defer to the guys with the degrees on the wall.
That's just me.
Re: Can you/do you run QTP tires tubeless???? [Re: Thumperdart] #678160
04/23/10 01:34 PM
04/23/10 01:34 PM
I just got off the phone with Dan from Hoosier in Manchester,Ct. I asked him what he thought about running tubes WITH the QTP's. He said the ONLY reason Hoosier recomends tubes with the QTP's is because over time,air will leak out.If you are going to race the car all the time,you should NOT run tubes. He said you can,but it is better not to run the tubes when racing.
What I have found with mine are, if my car sits for a long period of time,they go flat but if I drive it 2-3 times a week,they dont.
Re: Can you/do you run QTP tires tubeless???? [Re: MIKES_DUSTER] #678161
04/23/10 01:43 PM
04/23/10 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ANY tire will go flat over time.......even your production car/truck tires do. Funny, so Hoosier DOES NOT recommend tubes after all...............
Re: Can you/do you run QTP tires tubeless???? [Re: MIKES_DUSTER] #678162
04/23/10 01:46 PM
04/23/10 01:46 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
was told by the Hoosier dealer in town that tubes are not needed.
soapy water showed that a set of Quick Times i once had leaked air at the point where the date code(?) was cast into the tire.
Re: Can you/do you run QTP tires tubeless???? [Re: Thumperdart] #678163
04/23/10 01:49 PM
04/23/10 01:49 PM
I didnt say that.
Re: Can you/do you run QTP tires tubeless???? [Re: MIKES_DUSTER] #678164
04/23/10 02:01 PM
04/23/10 02:01 PM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
I have them, and run them tubeless.
Re: Can you/do you run QTP tires tubeless???? [Re: Mopar Ron] #678165
04/23/10 02:20 PM
04/23/10 02:20 PM
well thanks for the info and suggestions
I think I am going to run them tubeless for now and see how it goes
Re: Can you/do you run QTP tires tubeless???? [Re: Mopar Ron] #678166
04/23/10 04:59 PM
04/23/10 04:59 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
If you run tubes you better also screw the tires to rim when you have some power in the motor.
I ran a couple of runs with QTP's but since I didn't want to drill my steel wheels I ran them tubeless.
Did have a bit of trouble of getting them to seal on the wheelbeads, so I layed down a bead of silicon-rubber in the wheels before mounting them.
This is what had happened after just one run, look at the marks...
Eventually the silicon started to wad up in the beads causing a small leak themselves again.
So don't do as I did
Re: Can you/do you run QTP tires tubeless???? [Re: BigBlockMopar] #678167
04/23/10 05:17 PM
04/23/10 05:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Goes wthout saying about the rim screws...........
Re: Can you/do you run QTP tires tubeless???? [Re: Thumperdart] #678168
04/23/10 05:23 PM
04/23/10 05:23 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
We run slicks on steel wheels with no tubes, works great but they do air down when they sit for a week.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Can you/do you run QTP tires tubeless???? [Re: 65signet] #678169
04/23/10 07:10 PM
04/23/10 07:10 PM
These are the wheels I plan to run(ordered them today)
and even though I hate to do that to brand new wheel,
YES I am going to drill and screw the tires Ron...
Re: Can you/do you run QTP tires tubeless???? [Re: Mopar Ron] #678170
04/23/10 07:21 PM
04/23/10 07:21 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If your going to go tubeless, before drilling those wheels I would soap the insides of the tires with dawn dish soap, clean the outer bead and coat with 3-m rubber trim [ yellow death ] adheasive.
Re: Can you/do you run QTP tires tubeless???? [Re: Mopar Ron] #678171
04/23/10 07:30 PM
04/23/10 07:30 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I never run tubes. Never ever. My tire Guy said the ONLY thing a tube does is help the tire hold air. Hoosier says they are tube type because they have a tendency to leak air. But, I have not had one lately that leaked much air if any. Right now my Right tire will leak about a pound in one week, but did not do that when it was new. It's BALD now
Some say that a tube will add strength or integrity to the sidewall, but I am not so sure about that.
If you screw those breand new wheels you are crazy
I just do not run them at the strip with the lower air pressure too much until a couple weeks goes by and the soap dries. I do not go beloe #13 PSI if they are resently mounted and I mark them and watch them. If they move a couple inches on a run I am OK with that. But I have had one go 3/4 the way around in 4 runs before with no problems. But like I said, I shoot for something less than that
SRT DEMON ONE SEAT
