Brake lines probs is proportioning valve right? #677831
04/23/10 12:05 AM
04/23/10 12:05 AM
KS
MoparKansas Offline OP
KS
I went to put new brake lines on my Challenger and they don't seem to line up right. Here is a couple of photos. None of the fittings seem to be the right size and the bends on the part going to the mc aren't close. I am going by memory somewhat on where everything goes - am I thinking right?
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677832
04/23/10 12:06 AM
04/23/10 12:06 AM
KS
KS
Here is the old vs. new. And I am putting a new MC on BTW...
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677833
04/23/10 12:11 AM
04/23/10 12:11 AM
KS
KS
New fittings are larger also...old is on top.
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677834
04/23/10 01:01 AM
04/23/10 01:01 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What year?
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677835
04/23/10 01:17 AM
04/23/10 01:17 AM
you can bend 3/16" brake lines by hand wo kinking if they're the regular parts house ones that are not hardened material. See if reducer bushings are available from Earls etc or cut reflare your ends
Re: Brake lines probs is proportioning valve right? [Re: Snoopy] #677836
04/23/10 01:27 AM
04/23/10 01:27 AM
Snoopy Offline
Snoopy  Offline
73
Re: Brake lines probs is proportioning valve right? [Re: Snoopy] #677837
04/23/10 01:32 AM
04/23/10 01:32 AM
Snoopy Offline
Snoopy  Offline
73 E-Body Disc Brake System
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677838
04/23/10 02:10 PM
04/23/10 02:10 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Looks like a 70-71 kit
NS1AAR
Re: Brake lines probs is proportioning valve right? [Re: RapidRobert] #677839
04/23/10 04:06 PM
04/23/10 04:06 PM
KS
KS
They are stainless from one of the usual suppliers (not going to bash them unless they refuse to make it right) and the car is a 73 Challenger. I though I had most of it correct, but I just wanted to be sure. I know that they usually require a little tweaking, but I don't want to mess with re-flaring when I paid to have them be correct. Thanks for your help everyone. I just sent the pics off to the supplier.
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677840
04/23/10 04:13 PM
04/23/10 04:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Your MC in your picture is not stock, maybe that's where the confusion comes in.
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677841
04/23/10 04:15 PM
04/23/10 04:15 PM
Cincinnati, Ohio
Cincinnati, Ohio
And those old/cut lines are bent by hand... there not stock or original.
Get a stock MC and I bet everything fits.
Re: Brake lines probs is proportioning valve right? [Re: Challenger 1] #677842
04/23/10 04:18 PM
04/23/10 04:18 PM
KS
KS
Yeah, but the lines are the stock ones and they worked fine when I converted to the non-power brakes. I do remember doing a little bending to get them to line up. I didn't tell the company that it was manual brakes either.
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677843
04/23/10 04:20 PM
04/23/10 04:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
Well I'm sure it would matter if it's power or not as far as brake lines.
Re: Brake lines probs is proportioning valve right? [Re: Challenger 1] #677844
04/23/10 04:24 PM
04/23/10 04:24 PM
KS
KS
How can you tell they are not stock? My brother or myself have owned this car since 1990 or so and we never replaced them. I think the one line would work, but the short one is way too short even for a stock setup especially power as it would raise it another couple inches.
Re: Brake lines probs is proportioning valve right? [Re: Challenger 1] #677845
04/23/10 04:27 PM
04/23/10 04:27 PM
KS
KS
To clarify even though I will be using manual brakes I told them it was power brakes as I knew the lines on it worked before.
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677846
04/23/10 04:40 PM
04/23/10 04:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
Your never bend stainless, after it's bent like that.
Should have told them exactly what your using parts wise, so they can make the right lines for you.
Like what the other guys said, you can make those easy with reg steel brake lines from the auto parts store, plus then they will seal.
Tip on the stainless lines, lub the fittings well so you can really get them tight, cause there gonna need to be really tight to seal. Stainless is hard.
Good luck with it.
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677847
04/23/10 04:55 PM
04/23/10 04:55 PM
Cincinnati, Ohio
Cincinnati, Ohio
Because the master cylinder is not stock.
Re: Brake lines probs is proportioning valve right? [Re: Challenger 1] #677848
04/23/10 05:02 PM
04/23/10 05:02 PM
KS
KS
Hmmm never thought about not being able to bend the stainless. I just knew I had done it before. The first one I tried to hook up was the passenger side line and the fitting was too large, but I did have to rebend it a couple of inches by hand so it lined up with the port. And I am not changing master cylinders - I spent about 15 - 20 hours polishing an aluminum one like the one above!
Re: Brake lines probs is proportioning valve right? [Re: MoparKansas] #677849
04/23/10 05:06 PM
04/23/10 05:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
I hear ya! I bet if you tell them which MC your using, they could make em.
I know it sucks having those nice stainless lines and can't use em. Maybe they would take em back if you didn't install them or bend em.
Re: Brake lines probs is proportioning valve right? [Re: Challenger 1] #677850
04/23/10 05:54 PM
04/23/10 05:54 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Don't blame the line manufacturer. That is not the correct master for the car. The old lines you have pictured are hand bent not orignal. Why don't you use the correct master?
