Ballast Resistor #677825
04/23/10 12:02 AM
04/23/10 12:02 AM
Berkeley, IL
Mopar Tom 73 Offline OP
Berkeley, IL
I have a 75' Cordoba, 318. When car is running the ballast resistor gets hot and starts smoking. Can anybody steer me towards the problem or what I should check for?
Thanks, Tom
Re: Ballast Resistor [Re: Mopar Tom 73] #677826
04/23/10 12:06 AM
04/23/10 12:06 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
If you feel it excessive, coil primary resistance could be a cause, but the resitor getting hot is Pretty normal.
If there is foriegn debris on the resistor, it will smoke. It is quite common for the wire element to get hot enough to glow.
Re: Ballast Resistor [Re: Mopar Tom 73] #677827
04/23/10 12:11 AM
04/23/10 12:11 AM
A brand new one? Stock 4 terminal type ballast? Some smoke when new and it's a good idea to carry a spare
Re: Ballast Resistor [Re: RapidRobert] #677828
04/27/10 03:33 PM
04/27/10 03:33 PM
Berkeley, IL
Berkeley, IL
Thanks guys.
