Spicer U-joint retainers?? #677783
04/22/10 11:00 PM
04/22/10 11:00 PM
Out West
408strokerdart Offline OP
Out West
Does anyone know if they make different thickness retainers for 1350 series u-joints? I can't get the retainers in my Mark Williams yoke. Mine measure a consistant .058" thick and I need at least .010 less total (so about .005" thinner retainer) just to get them in. They were tight before on my old shaft, but these are a no go on this one. Any ideas?
Re: Spicer U-joint retainers?? [Re: 408strokerdart] #677784
04/23/10 12:32 AM
04/23/10 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you talked to MW about your issue? I'm sure they
should have what you need
Re: Spicer U-joint retainers?? [Re: MR_P_BODY] #677785
04/23/10 07:00 AM
04/23/10 07:00 AM
Out West
Out West
Haven't talked with anyone....just discovered it. I might try calling them today.
Re: Spicer U-joint retainers?? [Re: 408strokerdart] #677786
04/23/10 08:17 AM
04/23/10 08:17 AM
Hemiroid Offline
Hemiroid  Offline
The surface grinder is your friend. If all you need is .005, I'd just wack that off of the clips if you have access to a grinder. Car looks awesome by the way
Re: Spicer U-joint retainers?? [Re: Hemiroid] #677787
04/23/10 08:39 AM
04/23/10 08:39 AM
Out West
Out West
Thanks. This is the path I was going down if there were not thinner clips available.
Re: Spicer U-joint retainers?? [Re: 408strokerdart] #677788
04/23/10 10:45 AM
04/23/10 10:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
How wide are the grooves in the new yoke and how far apart are they BTW, the grooves really need to be centered in the yoke so the driveshaft does not wiggle or shake
Re: Spicer U-joint retainers?? [Re: Cab_Burge] #677789
04/23/10 10:25 PM
04/23/10 10:25 PM
Out West
Out West
Got it together.....just needed a little more persuasion.
I did find out something interesting though....I almost have to have the rear end out of the car to get the driveshaft in. This would have been nice to know before putting it in.
Re: Spicer U-joint retainers?? [Re: 408strokerdart] #677790
04/23/10 11:28 PM
04/23/10 11:28 PM
I forgot to ask which way you where trying to install the keepers, sharp side in or sharp side out, it makes a difference if there is a difference on your retainers. Round side out may pop out
Re: Spicer U-joint retainers?? [Re: Cab_Burge] #677791
04/24/10 12:05 AM
04/24/10 12:05 AM
Out West
Out West
I inspected them pretty close and couldn't see a difference on either edge. They are snug to say the least.
