Re: School me on the advantages of a Hydo-Boost system.
[Re: Challenger_Nut]
#677552
04/22/10 08:33 PM
04/22/10 08:33 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
After the 3-4 heated autocross stops you may not have the leg power to continue to stop the car as easily as a hydro boosted car. Brakes will fad and with repeated use, some may will require more pressure. That’s not to say all will.
With a Vacuum boosted car there is no way the vacuum can keep up with a modified motor having less than stock vacuum.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#677553
04/22/10 08:36 PM
04/22/10 08:36 PM
Posts: 7,759 So Cal
HealthServices
So Cal
It is a little harder to modulate the brakes but you can do it. I have it on my truck and it works well. Kenny brought his Duster (?) to the Spring Fling and it has Hydro boost.
Allen
#677554
04/22/10 08:46 PM
04/22/10 08:46 PM
Posts: 7,759 So Cal
HealthServices
So Cal
The one problem I had with hydro boost (in the 1 ton truck) is you have only one good stop if the motor is off, and in a 1 ton truck pulling a trailer, its kind of hard to turn and stop the thing. I'm sure in a light car such as yours you will not have that kind of problem.
Allen
#677555
04/22/10 09:10 PM
04/22/10 09:10 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I have it in my truck too...and did not notice any problem, but I don't tow a trailer all too often..
[Re: OzHemi]
#677556
04/22/10 09:21 PM
04/22/10 09:21 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I ran out of diesel about a 1/8 mile from the off ramp, coasting, but with a trailer and a car. I had to hit the brakes a little to make the turn and did not have anything left for stop at the gas pump! Both feet pushing on the pedal I thought for sure the steering wheel was bent when I finally stopped. Thinking back I should of used the trailer brake for the turn and the reserve for the stop at the pump.
Allen
[Re: OzHemi]
#677561
04/23/10 01:17 AM
04/23/10 01:17 AM
Posts: 7,759 So Cal
HealthServices
So Cal
With the hydro boost there is a small cylinder that holds a charge, it is supose to give you one good stop.
Allen
[Re: OzHemi]
#677563
04/23/10 02:35 AM
04/23/10 02:35 AM
Posts: 7,759 So Cal
HealthServices
So Cal
I believe this part is nitrogen filled, (some are a spring now) the power steering pump pushes the piston back and excess pressure is used for stopping. If the pump pressure is not there the nitrogen pressured piston gives you one good stop.
Allen
#677564
04/23/10 03:00 AM
04/23/10 03:00 AM
Posts: 6,516 Santa Cruz, California
Lefty
Please tell me why I would want to part with another $700.
Definitely try the manual brake setup first. There are advantages like always having the same pedal feel and stopping power regardless if the engine is running or not. Also I'm of the opinion there is better feel to the pedal as far as braking right on the edge of lockup.
Your setup sounds like it may perform fine without the extra boost, but that is up to you to decide. The brakes may take a little getting used to, but I would try manual first, you can always add the booster later. I've installed two of the Wilwood 7/8" MC on a manual setup and liked it.
