School me on the advantages of a Hydo-Boost system. #677549
04/22/10 08:27 PM
04/22/10 08:27 PM
WV.
Challenger_Nut Offline OP
WV.
Dumb question but what is the advantage of the hydo boost? I understand the vaccum issue and packaging along with not having to deal w/ a P.B. booster on a conversion from manual brakes......
What I am really asking, is there a performance advantage or is it just for the reasons I have stated above? I have just ordered the Wilwood 6 Piston front and 4 Piston rear kits and was planning on the 7/8ths Wilwood master cylinder for a manual set-up. I want the brakes to perform for spirited Mountian road driving here in West Virginia and possibly some autocrossing. Please tell me why I would want to part with another $700.
Re: School me on the advantages of a Hydo-Boost system. [Re: Challenger_Nut] #677550
04/22/10 08:29 PM
04/22/10 08:29 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I believe aside from the vacuum issue, hydo-boost can generate a higher braking pressure perhaps, which is why they are used from the factory on heavier duty 3/4 and 1 ton pickups...(that might not generate enough added boost with vacuum alone) ?
Of course you need power steering to run it too, which figure most people with power brakes would already have.
Re: School me on the advantages of a Hydo-Boost system. [Re: Challenger_Nut] #677551
04/22/10 08:32 PM
04/22/10 08:32 PM
Illinois
ChrisDavis Offline
ChrisDavis  Offline
Illinois
I have one on my car. I am very happy with it. The only advantage you missed is that it can easily develop 2000 psi + of line pressure. That is significantly more than vacuum assist. My pedal is fairly sensitive, but is no problem. Make sure the rest of the brake system is up to it.
Re: School me on the advantages of a Hydo-Boost system. [Re: Challenger_Nut] #677552
04/22/10 08:33 PM
04/22/10 08:33 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
After the 3-4 heated autocross stops you may not have the leg power to continue to stop the car as easily as a hydro boosted car. Brakes will fad and with repeated use, some may will require more pressure. That’s not to say all will.
With a Vacuum boosted car there is no way the vacuum can keep up with a modified motor having less than stock vacuum.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677553
04/22/10 08:36 PM
04/22/10 08:36 PM
So Cal
So Cal
It is a little harder to modulate the brakes but you can do it. I have it on my truck and it works well. Kenny brought his Duster (?) to the Spring Fling and it has Hydro boost.
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677554
04/22/10 08:46 PM
04/22/10 08:46 PM
So Cal
So Cal
The one problem I had with hydro boost (in the 1 ton truck) is you have only one good stop if the motor is off, and in a 1 ton truck pulling a trailer, its kind of hard to turn and stop the thing. I'm sure in a light car such as yours you will not have that kind of problem.
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677555
04/22/10 09:10 PM
04/22/10 09:10 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I have it in my truck too...and did not notice any problem, but I don't tow a trailer all too often..
Re: School me on the advantages of a Hydo-Boost system. [Re: OzHemi] #677556
04/22/10 09:21 PM
04/22/10 09:21 PM
So Cal
So Cal
I ran out of diesel about a 1/8 mile from the off ramp, coasting, but with a trailer and a car. I had to hit the brakes a little to make the turn and did not have anything left for stop at the gas pump! Both feet pushing on the pedal I thought for sure the steering wheel was bent when I finally stopped.
Thinking back I should of used the trailer brake for the turn and the reserve for the stop at the pump.
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677557
04/22/10 09:24 PM
04/22/10 09:24 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That just goes to show don't run out of fuel, and your brakes will be fine in general.
Re: School me on the advantages of a Hydo-Boost system. [Re: OzHemi] #677558
04/22/10 11:32 PM
04/22/10 11:32 PM
So Cal
So Cal
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677559
04/23/10 12:22 AM
04/23/10 12:22 AM
id usa
4spdfury Offline
4spdfury  Offline
id usa
Wouldnt it have been just as hard to stop if it had vaccum brakes. If the engine is not running you are not producing vaccum to operate the vaccum booster.
Re: School me on the advantages of a Hydo-Boost system. [Re: 4spdfury] #677560
04/23/10 12:27 AM
04/23/10 12:27 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
With a vacuum booster you usually have enough left for a couple of pumps when the engine shuts off...with hydro-boost..once the power steering pump stops turning, you have zero boost.
Re: School me on the advantages of a Hydo-Boost system. [Re: OzHemi] #677561
04/23/10 01:17 AM
04/23/10 01:17 AM
So Cal
So Cal
With the hydro boost there is a small cylinder that holds a charge, it is supose to give you one good stop.
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677562
04/23/10 01:29 AM
04/23/10 01:29 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I didn't know that...(or ever noticed it )
Re: School me on the advantages of a Hydo-Boost system. [Re: OzHemi] #677563
04/23/10 02:35 AM
04/23/10 02:35 AM
So Cal
So Cal
I believe this part is nitrogen filled, (some are a spring now) the power steering pump pushes the piston back and excess pressure is used for stopping. If the pump pressure is not there the nitrogen pressured piston gives you one good stop.
Re: School me on the advantages of a Hydo-Boost system. [Re: HealthServices] #677564
04/23/10 03:00 AM
04/23/10 03:00 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Definitely try the manual brake setup first. There are advantages like always having the same pedal feel and stopping power regardless if the engine is running or not. Also I'm of the opinion there is better feel to the pedal as far as braking right on the edge of lockup.
Your setup sounds like it may perform fine without the extra boost, but that is up to you to decide. The brakes may take a little getting used to, but I would try manual first, you can always add the booster later. I've installed two of the Wilwood 7/8" MC on a manual setup and liked it.
Re: School me on the advantages of a Hydo-Boost system. [Re: Lefty] #677565
04/23/10 03:05 AM
04/23/10 03:05 AM
So Cal
So Cal
You will get the best feedback with the manual brakes
Re: School me on the advantages of a Hydo-Boost system. [Re: Lefty] #677566
04/23/10 08:28 PM
04/23/10 08:28 PM
WV.
WV.
Thanks for all of the feedback.
Lefty, That was my original thought..... I would start with the manual setup and add the H-Boost if needed. I just don't like the idea of spending $300 on the 7/8 ths M.C. only to spend another $300 a new M.C. if I go with the H.B. system if I can avoid it.
My biggest concern is the loss of feel of what my car is doing as far as the brakes go, especially knowing when the point of lock up is knocking at the door.
As far as performace in regards to stopping distance and stopping power does the H.B... make that much difference or can I get the same results with the manual system but just have to apply more pedal pressure? Also in reality am I going to experience much fade on my mountain runs or is it just during an autocross event that I will experience it?
Re: School me on the advantages of a Hydo-Boost system. [Re: Challenger_Nut] #677567
04/23/10 09:05 PM
04/23/10 09:05 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
It made a big difference in stopping power on my charger. I went with a hydroboost because there wasn't a stock 4 wheel disc vacuum brake booster. I went with a 1.25" bore piston to have a better pedal feel. You are supposed to have 2-3 stops with the engine off with a properly working accumulator. Mine does about two and a half. There is also an optional longer accumulator, which I think offers more stops. But they are usually mounted on the higher-output hydroboost units, so you might want to buy one with a gold accumulator and swap in the long one. Another benefit is valve cover clearance (If you mount it upside-down). I can take out the driver's side master cylinder without toughing the booster, master cylinder or lines.
