Cheeta Valve Body Question? #677465
04/22/10 05:50 PM
04/22/10 05:50 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I have a 727 behind a mild 383 in a B-body. The trans. is supposed to have a"shift-kit" installed on its last overhaul.
Shifts like CRAP! lots of overlap,not real firm. Acts more like stock to me.
I have a couple Cheeta V/B `s since I run a Jerico in the racecar now.
Can you just install a Manual V/B?
Or is that death to an otherwise stock trans.?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Cheeta Valve Body Question? [Re: 6bblFLASH] #677466
04/22/10 06:05 PM
04/22/10 06:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
If the trans is in good shape it will work fine.The 727's we use are basically stock TorqueFlites with a Turbo Action O/haul kit,T/A converter,valve body and a Mopar deep pan.
Nautilus Racing-
