Do vacuum leaks affect a proper timing setting? #677462
04/22/10 05:40 PM
04/22/10 05:40 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
I timed the engine on my truck(400-2v) and a few days later I discovered the Carb mounting bolts were very loose.
I tightened the bolts up,and was wondering if I should recheck the timing,or would the vacuum leak have not affected the timing setting?
Re: Do vacuum leaks affect a proper timing setting? [Re: SPWC] #677463
04/22/10 05:47 PM
04/22/10 05:47 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I am not sure, I would say maybe but I would definitely recheck it, because everything can affect something else in your tune up, then you will know for sure.
Re: Do vacuum leaks affect a proper timing setting? [Re: SPWC] #677464
04/22/10 05:59 PM
04/22/10 05:59 PM
only if a rpm increase from the leak upped the idle to the point where it was starting to adv the dist springs but I dont think so here
