727 ? #677438
04/22/10 04:04 PM
04/22/10 04:04 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
How do you tell the difference between a pre 70 torqueflite and a 70 and up torqueflite. The reason i ask is i need to buy a rebuild kit for my trans and not sure what it is.
Thanks for any and all info
Re: 727 ? [Re: 604 Hemi GTX] #677439
04/22/10 04:11 PM
04/22/10 04:11 PM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
I know very little about transmissions, but I'll take a stab until someone else answers. I believe the 69 and earlier ones had fewer, but bigger splines on the input shaft, therefore using a different torque converter. I don't remember how many. I'm not much help.
Re: 727 ? [Re: 440Brian] #677440
04/22/10 04:15 PM
04/22/10 04:15 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
above the pan..stamped into the side of the trans..there is a part number...that part number will tell ya the year..
post the numbers..and someone will tell ya what year it is..
Tony
70 AARCuda Vitamin C
Re: 727 ? [Re: 440Brian] #677441
04/22/10 04:15 PM
04/22/10 04:15 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
The input spline diff is from the 66 to 67.
HOW you tell the diff in the 70's ... is the valve-body.
Re: 727 ? [Re: BeEtLeJuIcE !] #677442
04/22/10 06:05 PM
04/22/10 06:05 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
Early models have a narrow front pump bushing. 1970 up have a wide front pump bushing.As you open it up the pump is the first thing out, just take a look at it first. Hope this helps.
Re: 727 ? [Re: DAYTONA540] #677443
04/22/10 06:26 PM
04/22/10 06:26 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Look at the pump. Metal plate covering vent at the top. 70 and back. No plate over the vent? 71 and up. Unless it's been into before?
Re: 727 ? [Re: 604 Hemi GTX] #677444
04/22/10 07:59 PM
04/22/10 07:59 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Post the number on the pan rail after the "PK", or look in the tech archives.
Re: 727 ? [Re: Leigh] #677445
04/22/10 09:45 PM
04/22/10 09:45 PM
ONTARIO,CANADA
ONTARIO,CANADA
I'll take a look for the number on the trans tommorow and post the number.Thanks for all the help.
Re: 727 ? [Re: 604 Hemi GTX] #677446
04/23/10 12:57 AM
04/23/10 12:57 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think everyone covered it?
The input spline count change over was between the '66 anf '67 model year.
The 70 and earlier transmissions used a front pump with just a metal shield covering the vent. The later pump has a plastic baffel. The stator support (bolts to back of pump, and fit into the front drum) is different because the front clutch drum used a wider bushing from '71 and up.
The front servo is slightly different. The early servo uses a smaller diameter pushrod, and the later servo uses a load controlled / larger diameter pushrod. The rear diaphram spring is different, The later valve bodies usually have the part throttle kick down assembly. I don't know the year when they changed the governor design that has the small cone filter in it?
I'm sure there are a few other changes, but I doubt it would affect the rebuild kit selection.
I think all the aftermarket front drums require the use of the newer style stator support (That is normally on the newer style pump.)
At least it is not a pre '66 model with the rear pump and cable shift / park setup
Re: 727 ? [Re: 604 Hemi GTX] #677447
04/23/10 12:42 PM
04/23/10 12:42 PM
NC
440Jim Offline
440Jim  Offline
NC
From John Kunkel's photo site:
Pre-'71 case has center pipe plug low near the pan rail.
See attachment.
Re: 727 ? [Re: 440Jim] #677448
04/23/10 12:42 PM
04/23/10 12:42 PM
NC
440Jim Offline
440Jim  Offline
NC
'71 and later case has center pipe plug higher up.
See attachment.
Re: 727 ? [Re: 727builder] #677449
04/23/10 12:47 PM
04/23/10 12:47 PM
NC
440Jim Offline
440Jim  Offline
NC
Attached pic of '71 and up.
Re: 727 ? [Re: 440Jim] #677450
04/24/10 03:00 PM
04/24/10 03:00 PM
ONTARIO,CANADA
ONTARIO,CANADA
I found a few numbers on the trans.I found one number on the right side of the bell housing #1G116071 and i found one on the left side of trans on pan rail #35158451 3325 7853
Re: 727 ? [Re: 604 Hemi GTX] #677451
04/24/10 03:48 PM
04/24/10 03:48 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
3515845 is from a 71 Plymouth, Dodge or Chrysler with a 383 2BBL. But that is just the case marking. If it has been rebuilt at any time, no telling what has been changed inside.
