How far should radiator fan extend into shroud? #677290
04/22/10 01:31 PM
04/22/10 01:31 PM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
I am in the midst of an engine swap- 440. Old set up is being replaced by Mopar aluminum water pump and housing and Bouchillion single groove water pump pulley.
The fan only extends a little into the shroud, whereas before it seemed like it was further in. So how far should the radiator fan extend into the shroud?
Could I have put the fan on backward?
Could the swap to a different water pump/housing and pulley changed the distance?
Thanks!
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: How far should radiator fan extend into shroud? [Re: YGBSM] #677291
04/22/10 01:36 PM
04/22/10 01:36 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The rule of thumb I've always heard was to have an inch between the fan and radiator for otpimum cooling, so you could use that to determine if your fan is far enough into the shroud.
Re: How far should radiator fan extend into shroud? [Re: YGBSM] #677292
04/22/10 01:42 PM
04/22/10 01:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I thought the optimum distance was to have the fan about half way into the shroud..
With it all the way in, there was more turbulance or such...
Re: How far should radiator fan extend into shroud? [Re: YGBSM] #677293
04/22/10 01:42 PM
04/22/10 01:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
From what I understand the fan blade should be half way into the shroud.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: How far should radiator fan extend into shroud? [Re: HealthServices] #677294
04/22/10 01:47 PM
04/22/10 01:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah but I don't think a 1/4" either way is going to kill you
Coming soon!!!!
Re: How far should radiator fan extend into shroud? [Re: YGBSM] #677295
04/22/10 02:07 PM
04/22/10 02:07 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
1/2" to 3/4" Is what was listed in the instructions for the after-market fans I've installed over the years.
Re: How far should radiator fan extend into shroud? [Re: Lefty] #677296
04/22/10 08:25 PM
04/22/10 08:25 PM
1/2" to 3/4"
I'd prefer a bit closer to 3/4 of it inside the shroud
Re: How far should radiator fan extend into shroud? [Re: YGBSM] #677297
04/22/10 09:01 PM
04/22/10 09:01 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Blade should be half in...half out
