How far should radiator fan extend into shroud?
#677290
04/22/10 01:31 PM
04/22/10 01:31 PM
Posts: 447 Knoxville, TN
YGBSM
Knoxville, TN
I am in the midst of an engine swap- 440. Old set up is being replaced by Mopar aluminum water pump and housing and Bouchillion single groove water pump pulley.
The fan only extends a little into the shroud, whereas before it seemed like it was further in. So how far should the radiator fan extend into the shroud? Could I have put the fan on backward? Could the swap to a different water pump/housing and pulley changed the distance?
Thanks!
1968 Charger R/T 2015 Charger R/T Scat Pack 2017 Durango Citadel
Re: How far should radiator fan extend into shroud?
[Re: YGBSM]
#677293
04/22/10 01:42 PM
04/22/10 01:42 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
From what I understand the fan blade should be half way into the shroud.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#677294
04/22/10 01:47 PM
04/22/10 01:47 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah but I don't think a 1/4" either way is going to kill you
[Re: YGBSM]
#677295
04/22/10 02:07 PM
04/22/10 02:07 PM
Posts: 6,516 Santa Cruz, California
Lefty
1/2" to 3/4" Is what was listed in the instructions for the after-market fans I've installed over the years.
