Stock Intake Manifold vs Edelbrock DP4B/CH4B #677210
04/22/10 11:58 AM
04/22/10 11:58 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Ive got to change the intake manifold on my 440. I have a dual feed Holley and the fast idle adjustment interferes with the pad for the stock choke so I had to remove it, thus no fast idle with the choke and a very smelly, plug fouling warm up cycle. Also, the coil will not mount in the stock location with the huge dual feed bowl in the way.
I can pick up a CH4B from a friend cheap. I would prefer a Performer RPM later on when I change the cam. How much of a gain over the stock manifold is the CH4B? I know it was replaced with the regular Performer which no one seems to like but people seem to like the CH4B. Anyone have any experience going from a stock to the CH4B?
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: GTX MATT] #677211
04/22/10 12:16 PM
04/22/10 12:16 PM
CHRGR69 Offline
CHRGR69  Offline
I have a DP4B on my 383 and the CH4B on my 440. Don't know how much of a gain, but with the same 4bbl Eddys on each, it improved throttle response for sure. Do it. You will be glad you did. I was!
Grandma always said I had "hands of gold"!
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: CHRGR69] #677212
04/22/10 12:35 PM
04/22/10 12:35 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
The OLD CH4B/DP4B debate !!
These manifolds are nothing more than a basic-copy of an iron manifold ... cast in aluminum.
What I would do - if I were you ... is to pick that CH4B ... and SELL IT (to the people who think that it is so valuable) ...and BUY a Perf-RPM !!
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: dOrk !] #677213
04/22/10 01:35 PM
04/22/10 01:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Actually side by side, the ch4b is a little larger than a stock intake. It's an improvement, but whether it's worth it depends a lot on the rest of the build. With stock unported heads and revving to 5500 or less, you can't go wrong with the ch4b. Revving to 6k with aftermarket heads, the nod goes to the RPM intake. Keep in mind the ch4b will provide a little better throttle response than the rpm.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: DaytonaTurbo] #677214
04/22/10 03:34 PM
04/22/10 03:34 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
BUT a BESTer choice here would be an SP2P or a Streetmaster....as far as 5500 rpm or less and if you are concerned with low-speed throttle response.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: dOrk !] #677215
04/22/10 04:50 PM
04/22/10 04:50 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Dont agree. The CH4B would be a better choice than either the above. If it were me, Id put a RPM on it now.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: dOrk !] #677216
04/22/10 05:45 PM
04/22/10 05:45 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The SP2P is worthless on anything...even a truck or motorhome. They give hardly any extra torque down low, and completely choke the motor. You would lose power going from a stock intake to a SP2P
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: Von] #677217
04/22/10 05:53 PM
04/22/10 05:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have see lot of ppl rating the old DP4B/CH4B eddy intakes allmost side to side with RPMs
so it looks is probably something in the middle of performer and RPM ?
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: NachoRT74] #677218
04/22/10 06:37 PM
04/22/10 06:37 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Used a CH4B on a 440 Charger RT and it picked up from 13.90 to 13.75 back in 1970. Otherwise all stock.
The little old lady from Pasadena is back!
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: 440newport] #677219
04/22/10 07:07 PM
04/22/10 07:07 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
...and your SPECIFIC experience(s) is what ?
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: dOrk !] #677220
04/22/10 07:16 PM
04/22/10 07:16 PM
440newport Offline
440newport  Offline
I knew a guy who bought a 318 dodge truck with one and a 650 eddy. The truck had 4.10 or 4.56 gears so it had to rev but that motor seemed like it was done at 3000rpm, the intake probably wasn't entirely at fault, but it certainly didn't help.
I've also seen various dyno sheets that showed it really had no advantage down low and gave up torque big time from the mid range on up.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: GTX MATT] #677221
04/22/10 07:56 PM
04/22/10 07:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
CH4B is a good choice for stock and mild performance applications. It is not an aluminum version of the stock manifold. The cross section and volume of the runners is larger, and is slightly taller.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: GTX MATT] #677222
04/22/10 10:39 PM
04/22/10 10:39 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
Dyno motor used here is more radical than what you're doing, but even so, here ya be : http://www.moparmusclemagazine.com/techa...test/index.html save it to your favorites for quick reference for when Doc tells you the CH4B is virtually the same as stock
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: forphorty] #677223
04/23/10 08:54 AM
04/23/10 08:54 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: Von] #677224
04/23/10 09:25 AM
04/23/10 09:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
psst the CH4B is a good intake and works well with mild applications, and is flows better than the stock intake, beside it's not the heat sink or the anchor that the old iron unit is.
Coming soon!!!!
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: 440newport] #677225
04/23/10 09:28 AM
04/23/10 09:28 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
oh and the SP2P is a joke. it was called the "economizer" that should give you an idea how good it is. I'd rather run a stock iron unit.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: dOrk !] #677226
04/23/10 10:10 AM
04/23/10 10:10 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
BS - CH for RB and DP for B engines are much better than the stock cast iron pieces. A step over the stock or even the Performer which is vertully nothing more than aluminum copy.
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: forphorty] #677227
04/23/10 10:46 AM
04/23/10 10:46 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
OK ....I will stand-corrected ... with ole S D doing the test and writing the article ... his knowledge and expertise impresses me ... but do you CHERRY PICK his knowledge to only fit your own agenda and bias ?
Me thimks MOST of you Berry-Bumz do !
IF you did-not ... all of you Bumz would be running a Plastic-Fantastic !
Oh ...and I guess that all-this makes the CH4B I have that is welded-up to fit max-wedge heads worth Big-Bux now !
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: 440newport] #677228
04/23/10 11:13 AM
04/23/10 11:13 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
I have never heard or seen an SP2P being "done" at 3000 rpm ....but since the ports of that intake are so small .. I would put-the-blame MOSTLY on that intake. But I will also bet that the guy you knew didn't try and massage that combo much .. if not at all.
Your dyno sheets ? ..... I would like to see those showing what you allege. And wasn't there a "dyno topic" here about a week or so ago that claiming an nicely-built A engine(but nothing fantastic) making something-like 850 horsepower ?
Do you KNOW what the purpose and the design of the SP2P was for ?
Re: Stock Intake Manifold vs Edelbrock DP4B/CH4B [Re: dOrk !] #677229
04/23/10 12:04 PM
04/23/10 12:04 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Who cares? The original poster only wanted to know if it was worthwhile to install a ch4b/dp4b over a stock intake. Question was answered.
This space available for rent
