Re: where can I get
[Re: klunick]
#677061
04/22/10 09:40 AM
04/22/10 09:40 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Are you looking for the O ring on the tube?
I might have one or 2
Re: where can I get
[Re: WILD BILL]
#677064
04/22/10 09:56 AM
04/22/10 09:56 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Every one I got in my tranny kits was an O ring and they never leaked. Kinda of a bear to get in some times though. They do look flat when they've been installed for a long time.
The o-ring picture at the NAPA site seems to thin. How fat are the ones you got? I guess it would flatten as they aged... It would seem they would have to be like 3/16" thick to work.
Re: where can I get
[Re: Mr.Yuck]
#677065
04/22/10 09:59 AM
04/22/10 09:59 AM
Posts: 15,487 Florida
scratchnfotraction
I use a new o-ring and some of the mopar black ATF sleezcone on it also makes it slid in ez-er and seals up nice tranz fluid resitant and last till it removed
Re: where can I get
[Re: scratchnfotraction]
#677066
04/22/10 10:16 AM
04/22/10 10:16 AM
WILD BILL
BROOK PARK, OH
No Idea, I'll have to take a look through some of the old kit boxes when I get home for ya
Re: where can I get
[Re: WILD BILL]
#677067
04/22/10 10:19 AM
04/22/10 10:19 AM
Mr.Yuck
Brookeville, Md
thanks.
Re: where can I get
[Re: Mr.Yuck]
#677068
04/22/10 11:03 AM
04/22/10 11:03 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
A/Trans O-Ring, Oil Fill Tube...... .....Attributes Trans O-Ring I.D. : .549" Trans O-Ring Thickness : .103"
yes but it's not an "O" ring. It's a flat ring. The O-rings don't seal to well.
Since you have the specs, seems you could also go to Ace Hardware (replace with you favorite local hardware or warehouse home improvement store) and get a couple or three; one size up and down and one, spot on.
Re: where can I get
[Re: Scott Carl]
#677069
04/22/10 11:05 AM
04/22/10 11:05 AM
Mr.Yuck
Brookeville, Md
I'm not sure that's fat enough but I guess I could go look.
Re: where can I get
[Re: Mr.Yuck]
#677070
04/22/10 11:15 AM
04/22/10 11:15 AM
Scott Carl
Omaha, Nebraska
Get two sizes up then
Re: where can I get
[Re: Scott Carl]
#677071
04/22/10 09:32 PM
04/22/10 09:32 PM
WILD BILL
BROOK PARK, OH
The one I have in the kit is .100" thick
Re: where can I get
#677072
04/23/10 12:28 AM
04/23/10 12:28 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
My old truck trans leaked from the tube even with a new seal. I found it had a small crack where the "O" ring goes. I put some Mopar black AFT sealer on it, and it never leaked again (That sealer rocks!)
FWIW, I has some of the Black sealer sitting in the garage because that is all Mopar uses to seal the trans pans on my '97 Chrysler Concord. They don't bother with gaskets on those
Re: where can I get
[Re: Mr.Yuck]
#677073
04/23/10 10:00 AM
04/23/10 10:00 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I have like a dozen of them in my tool box at home, how many do you want?
Rich H.
Esse Quam Videri
Re: where can I get
[Re: ZIPPY]
#677075
04/23/10 10:29 AM
04/23/10 10:29 AM
Mr.Yuck
Brookeville, Md
thanks...Wil Bill is going to send me one.
I don't know why parts stores don't carry them. I went to NAPA, Autozone and Advance. Maybe They just don't know what I'm talking about and if it's not in their computer they can't help you...
Re: where can I get
[Re: Mr.Yuck]
#677076
04/23/10 10:40 AM
04/23/10 10:40 AM
ZIPPY
S.E. Michigan
Probably that, yep.
For reference ATP Part # JO15 at Rockauto.com.......... 10 cents apiece
Rich H.
Esse Quam Videri
Re: where can I get
[Re: Scott Carl]
#677079
04/23/10 04:46 PM
04/23/10 04:46 PM
scratchnfotraction
yes,I have done that also clean pan and tranz with brake clean and use the the mopar black atf/rtv I smear a thin coat on the tranz flange and a thin coat on the pan not a lot just a good thin coat,let set up 15 mins or so install it I snug up the bolts with 1/4 ratchet,let cure over night,check agian in the am with the 1/4 ratchet and make sure its still snug didnt leak till removed that was in a pinch,I would rather use the new o-ring gasket from the dealer well worth the $ and upgrade to a reusable gasket used it on all the engine stuff last go round with the sb..VC,intake end seals,wp,t-cover,fuel pump...even glued the dip stick tube into the block thin coat on the gaskets and no leaks 4 yrs later still...now it blowing oil out the VC breather is another story
