67 charger front disc brake conversion
#676425
04/21/10 10:20 AM
04/21/10 10:20 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I am converting my front drum to disc and I found a dodge diplomat with front disc that I was thinking of using. I dont have any vacuum for power brakes so they will be manual. Has anyone done this conversion? And what kind of master did you use? And did it bolt directly to the firewall? I am mostly going to be drag racing it and very little street driving. It should be running around 10.50 range. Is this going to be enough brake with my stock drums in the rear? I eventually plan to change the rears to disc but im just trying to get it to the track this summer.Any other ideas would be great also.
67' charger 499 RB
10.57 at 127
Re: 67 charger front disc brake conversion
[Re: dragram440]
#676426
04/21/10 10:34 AM
04/21/10 10:34 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Get them and the PP valve.Then get a master for a 69 C body manual disc brakes.I have that on my 65.Stops great at 120.I use ceramic pad on mine.The master will bolt right on.Rocky
Chrysler Firepower
