quastion about timing #675930
04/20/10 07:26 PM
04/20/10 07:26 PM
windsor, onatrio canada
metcoll Offline OP
metcoll  Offline OP
i have a 440 bored 030 six-pack replacement pistons, lunati 240/250 & 520/547 hydraulic cam,mild 452 heads,rpm intake, 13/4 headers & 750 dbl. pump holley,just purchased a msd 8546 distributor, blaster 2 coil,& msd 6Abox vehicle is a 4000 lb b-body with 4200 stall & 4.56 gears...what timing should i set for the most performance,i have access to 94 octane gas, thx for any relpies...
Re: quastion about timing [Re: metcoll] #675931
04/20/10 07:54 PM
04/20/10 07:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look at about 18 initial and about 32 total and adjust
for best performance
383man [Re: MR_P_BODY] #675932
04/21/10 01:39 AM
04/21/10 01:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a 906 headed 440 with 10.0 comp and I run on 92 pump. I have my dist set for full advance by 2000 rpm and I like 36 to 38 for my best performance without any ping. I have quench in my 440 as I use quench pad pistons and it helps let me run more timing without ping then a non quench eng. With iron heads and no quench at 10.0 comp I dont think I could run 38 total. Ron
Re: quastion about timing [Re: metcoll] #675933
04/21/10 02:10 AM
04/21/10 02:10 AM
Most of the iron headed wedge motors like bewtween 34 and 38 degrees depending on compression ratio and local weather conditions. The higher the altitude the more timing they like also :scopeout Usually you want to run as much initial timing as you can without the motor kicking back on the starter and as much total timing as you can without pinging
