Re: Lower control arm weld on
[Re: bigblock340power]
#675914
04/20/10 06:49 PM
04/20/10 06:49 PM
Posts: 4,958 WI
Dcuda69
WI
Yep, that's it! Putting order in right now. Thank you.
Did ya order a set for me too?? On my list o'to do things!Can you post if they made a noticeable improvement? Thanks!
[Re: Dcuda69]
#675915
04/20/10 07:45 PM
04/20/10 07:45 PM
Posts: 31,074 Oregon
AndyF
Yep, Mancini sells them in the mid-west and www.firmfeel.com sells them for the west coast guys. Firm Feel will weld them on for you as well as add do the K frame stiffening if you want. Just need to send them the parts or pay a core charge.
[Re: Blakcharger440]
#675917
04/20/10 08:05 PM
04/20/10 08:05 PM
Challenger 1
Cincinnati, Ohio
Can those stiffening plates be welded onto the lower control arm while the arm is still on the car?
sure...
[Re: Dcuda69]
#675918
04/20/10 10:28 PM
04/20/10 10:28 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
I'll be a little while till I can post anything about how good they do. I'm putting the front suspension together and attaching the "K" to the engine. Then everything gets bolted to the car like the factory did it. Also, I'm using tubular upper "A" arms and alum. struts to really firm everything up. I'll be welding them (the plates) on the lower control arms off the car. So I can't answer the question about welding them on the car.
