Re: 727 shift overlap
[Re: CIB]
#675834
04/20/10 04:28 PM
04/20/10 04:28 PM
Posts: 26,009 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In manual low the rear band is applied, when you shift to 2nd the band must release and it's slow to release if the servo isn't modified....so the drag of the band as it's releasing causes overlap.
The band isn't applied when in Drive.
[Re: John_Kunkel]
#675835
04/20/10 04:30 PM
04/20/10 04:30 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
John how do you recomend modifying the servo? Do you think the shims to make it solid (or aftermarket solid servo)is a good idea?
[Re: HotRodDave]
#675836
04/20/10 04:33 PM
04/20/10 04:33 PM
John_Kunkel
Rio Linda, CA
The shims or solid servo don't help much without a stiffer spring, the combination of both the spring and rigid servo piston gives the best release possible.
