cast/forged crank #675820
04/20/10 04:15 PM
04/20/10 04:15 PM
ohio
2
2young2drive Offline OP
ohio
Its finally slipped my mind...
What year did they start using cast cranks rather than forged? Someone local has a 73 440 from an imperial. Just wondering which it is. (He doesn't know).
Re: cast/forged crank [Re: 2young2drive] #675821
04/20/10 04:31 PM
04/20/10 04:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'73 was the first year for the cast crank in the 440. HP engines were supposed to get forged cranks but standard performance could get either cast or forged at random. There are always exceptions.
Re: cast/forged crank [Re: John_Kunkel] #675822
04/20/10 04:36 PM
04/20/10 04:36 PM
ohio
2
ohio
Ok. I'll just have to pick it up and see. Its a complete engine for 200. Shouldn't be able to go wring with that.
Re: cast/forged crank [Re: 2young2drive] #675823
04/20/10 05:31 PM
04/20/10 05:31 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
For 2 hundred, you could flip it for a fast 50-100 w/o breaking a sweat.
Re: cast/forged crank [Re: Commando1] #675824
04/20/10 05:54 PM
04/20/10 05:54 PM
dulcich Offline
dulcich  Offline
73's were all forged in 440's; cast crank started in 1974, but forged still used in some applications.
-dulcich
Re: cast/forged crank [Re: dulcich] #675825
04/20/10 06:17 PM
04/20/10 06:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Nothing wrong with a cast 440 crank either. These aren't chevy 350's, the 440 cast cranks are still pretty strong.
Re: cast/forged crank [Re: dulcich] #675826
04/20/10 07:16 PM
04/20/10 07:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
-dulcich
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: cast/forged crank [Re: dulcich] #675827
04/20/10 07:28 PM
04/20/10 07:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
-dulcich
I disagree and so does the factory, check TSB 09-01-73C dated Oct. 11, 1972.
To quote...."The 1973 standard 440 will be built with either the forged or cast crankshaft..........The cast crankshaft engines are identified by the stamped letter "E" below the build date on the cylinder block information pad".
I have personally pulled a couple of '73 350 hp engines with cast crank and the "E" stamping.
Re: cast/forged crank [Re: John_Kunkel] #675828
04/20/10 07:59 PM
04/20/10 07:59 PM
dulcich Offline
dulcich  Offline
Not to stir the pot, but I haven't seen a factory 73 440 with a cast crank, though I can't say I've seen them all. The DC manuals have always listed 74 as the first year for the cast crank. I know the cast crank is noted in the 1974 factory service manual, but don't have a 1973 handy.
-dulcich
Re: cast/forged crank [Re: dulcich] #675829
04/21/10 05:32 PM
04/21/10 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't think the factory publishes TSB's just to exercise their printing equipment.
Re: cast/forged crank [Re: John_Kunkel] #675830
04/21/10 05:54 PM
04/21/10 05:54 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Used to work at a parts wholesalers where we would buy whole motors and disassemble them for resale to rebuild shops and I don't ever remember seeing a 1973 cast crank 440. Infact quite a few 74's were forged as well.
Re: cast/forged crank [Re: dulcich] #675831
04/22/10 06:37 PM
04/22/10 06:37 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
-dulcich
I have known 73s were already cast, and just 400s 4 speeds were still forged in 73.
although maybe some earliers could have been still forged due the stock at plant?
Re: cast/forged crank [Re: NachoRT74] #675832
04/23/10 12:02 AM
04/23/10 12:02 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I too have seen forged 74's, and cast 73's.
NEVER talk in absolutes, when talking about mopar builds.
Lot's of absolute myths about cranks, like.... all 273's were forged, all 400's were cast, all 383's were forged, all 72's 340's were forged, and the list goes on..... none of them true
The references are excellent guidlines, that are correct MOST of the time. Only a look at the motor will tell you for sure.
