Need advice on tuning my carb #675774
04/20/10 03:42 PM
04/20/10 03:42 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
I have a new edelbrock 650 on a 383 in a dart. Starts fine, idles fine after choke goes off, but when the car comes up to operating temperature it stalls when in drive and stopped? I am not good with carbs, and don't want to start adjusting things without knowing. Could anyone direct me please? I have a stock fuel pump right now, does it need a high flow? Scott
68 dart 383/727/3.55
Re: Need advice on tuning my carb [Re: revcon] #675775
04/20/10 03:44 PM
04/20/10 03:44 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Have you tried raising the idle rpm?
Re: Need advice on tuning my carb [Re: revcon] #675776
04/20/10 05:36 PM
04/20/10 05:36 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
It sounds like you're carb needs an insulator between it and the intake manifold or at least a sheetmetal heatshield. Those aluminum bodied AFB style carbs are prone to percolating when heat is transferred.
As far as a fuel pump, your problem is at idle, it doesn't take much to feed the motor at that time. It's a problem with the carb getting too hot or fuel mixture too lean, not a volume issue.
Re: Need advice on tuning my carb [Re: Dean_Kuzluzski] #675777
04/20/10 09:24 PM
04/20/10 09:24 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
Ok. do you mean a ceramic spacer between the carb and manifold or insulation between the intake and valley pan like from the factory?
Re: Need advice on tuning my carb [Re: revcon] #675778
04/20/10 10:26 PM
04/20/10 10:26 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I belive that insulation between the vally pan and intake is for sound deadining..to quiet the engine noise only..anybody else want to chime in on that..
Re: Need advice on tuning my carb [Re: revcon] #675779
04/21/10 09:11 AM
04/21/10 09:11 AM
Holly/MI
Holly/MI
No, a phenolic resin spacer. It looks like a black piece of plastic. Or a sheetmetal heatshield.
Re: Need advice on tuning my carb [Re: Dean_Kuzluzski] #675780
04/21/10 09:49 AM
04/21/10 09:49 AM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
Ok, Thanks. I will try that. Scott
Re: Need advice on tuning my carb [Re: revcon] #675781
04/21/10 10:50 AM
04/21/10 10:50 AM
what is your idle speed, how many turns out are the mixture screws, when it dies see if the AP still has a good squirt, have some crank it at that time & see if the coil wire held 1/4" from ground has a nice blue spark
Re: Need advice on tuning my carb [Re: revcon] #675782
04/21/10 12:03 PM
04/21/10 12:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
1st up get it off the hot intake, especailly if you are using a factory iron unit. Next go get a vacuum gauge. Turn your screws in all the way then back them out 1 1/4 turn, Hook up the vacuum gauge and adjust for the best vacuum reading. Then reset your idle. Now take a timing light and set your timing. A mild 383 will probably like 36-38* at 2400rpm. See if that fixes your problem.
Coming soon!!!!
Re: Need advice on tuning my carb [Re: Mr.Yuck] #675783
04/21/10 01:17 PM
04/21/10 01:17 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
I have a MP aluminum intake. I will try the spacer. How thick should the spacer be? How much room is in a dart (68) with a stock 383 in it? Can a 1" spacer fit? After that I will check the other settings. I had to pour some gas in thecarb when the fuel pump was failing and it evaporated really fast, so I am thinking the carb is getting too hot as mentioned. What do the heat shields look like? How are they installed?
Re: Need advice on tuning my carb [Re: revcon] #675784
04/21/10 01:59 PM
04/21/10 01:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd use a 4 hole 1/2" spacer. That should be enough. Make sure your choke flap isn't sucking shut when you drive.
Re: Need advice on tuning my carb [Re: Mr.Yuck] #675785
04/21/10 06:08 PM
04/21/10 06:08 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Ya kinda sounds like too rich maybe? The insulation between the intake and valley pan was for heat shielding not sound dampening...
Re: Need advice on tuning my carb [Re: Dusted_Ya] #675786
04/21/10 06:26 PM
04/21/10 06:26 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Get the insulating gasket from edelbrock It works. Make sure your choke is fully open when it comes off fast idle. Adjust your idle setting. It doesn't sound from your description that it's a boil problem. Fuel in the bowl won't boil in the short time from start up to coming off fast idle. Usually fuel boiling becomes a problem after the motor has been running at operating temp for a period of time. 10 minuites isn't long enough to get the intake that hot that it will boil the fuel. Make sure your not running to lean. That will cause excessive heat.
383man [Re: Mr.Yuck] #675787
04/21/10 06:44 PM
04/21/10 06:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not trying to be smart but you should always adjust the carb last when tuning. You always set the timing before the final carb adjustment. Ron
Re: Need advice on tuning my carb [Re: revcon] #675788
04/21/10 10:42 PM
04/21/10 10:42 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
when you say it stalls, does it die? if so, how does it restart?
Re: 383man [Re: 383man] #675789
04/22/10 08:11 AM
04/22/10 08:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I do all that a few times Ron...lol I set timing, do the carb, set the timing tune the carb...So yeah you're right, timing 1st.
carb [Re: Mr.Yuck] #675790
04/22/10 01:55 PM
04/22/10 01:55 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
When I start it, it idles high until I press the pedal, then it goes to a nice idle. Once I drive around for 20-30 minutes and come to a stop, it stops running. It restarts by pushing the pedal to the floor and holding it. Then I have to put it in neutral when I stop and give it some gas. I have the carb lean/rich setting on the line for the setting in between the two. I had it two notches rich, and a friend said to cut it back to even. Maybe I will advance it one notch to see what happens after I install the spacer.??
Re: carb [Re: revcon] #675791
04/22/10 02:08 PM
04/22/10 02:08 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
That adjustment you are refering to is the choke setting. It only affects cold starting. You have a problem after it is already warm. First when your car comes up to temp is your choke open all the way? If it is you need to set the 2 a/f screws in the front of carb for highest vacuum ready or highest smooth idle quality. If it does not then you need to work on why it isn't. If you still have a problem take it to someone that knows about that stuff. All the knowledge in the world on this sight can't help if you do not understand what they are talking about.
JAKES AUTOMOTIVE
Re: carb [Re: JAKE68] #675792
04/22/10 03:20 PM
04/22/10 03:20 PM
Holly/MI
Holly/MI
Agreed. Now that we have more info............
it sounds like either a vacuum leak or an extreme lean condition due to the lack of tuning.
Re: carb [Re: Dean_Kuzluzski] #675793
04/22/10 09:53 PM
04/22/10 09:53 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
I will admit I don't know much about Carbs, except consuming them. The information is all excellent, and I want to learn how to take care of the car myself. THANK YOU!
Now the vacuume was plugged when the car was assembled, and I was told it wasn't needed? Do I need to open that up and connect it? might that be the problem? I ordered the carb spacer.
