MSD 6AL test
#675665
04/20/10 01:39 PM
04/20/10 01:39 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Went to fire the 440 and no spark.It did start for a few seconds then quit.I have 6al dist and Blaster coil.Have power on small red to box and the large red and ground are good.Plug to dist is connected.I see no volts to coil with key on with DVOM.Any tests to run?I might swap my kids coil just to see if that is the problem.Rocky
Chrysler Firepower
Re: MSD 6AL test
[Re: therocks]
#675666
04/20/10 02:01 PM
04/20/10 02:01 PM
Posts: 119 Orangeville, Ontario, Canada
Red Express
check the gap on the elec points in the dist... I fought with a 6AL for months one winter and it ended up my gap was to big... I think it needs to be around .006"... which is a peice of paper folded in half.
worth a try.
Darcy & Allan MacCoubrey
Worlds Fastest Lil Red Express Truck
10.48 @ 128 mph
[url] www.raceosca.com [/url].
Re: MSD 6AL test
[Re: Red Express]
#675667
04/20/10 02:05 PM
04/20/10 02:05 PM
therocks
Niles , Ohio
Ill check it but the MSD dist has been running in it for 8 years at least.Had it running about a month ago and it was fine.Rocky
Chrysler Firepower
Re: MSD 6AL test
[Re: Posest]
#675669
04/20/10 04:12 PM
04/20/10 04:12 PM
Posts: 4,425 Michigan
MarkZ
Worthy
Worthy
Unplug the pickup, turn the ignition on, and jump the two wires together briefly. If the box is firing you'll definitely hear it. MSD boxes are noisy little critters.
Re: MSD 6AL test
[Re: MarkZ]
#675670
04/20/10 07:11 PM
04/20/10 07:11 PM
therocks
Niles , Ohio
I try unplugging the dist in the AM.My box has always been quiet.So I have to jump the wires that go to the box?I believe one is purple and cant remember the other color.Rocky
Chrysler Firepower
Re: MSD 6AL test
[Re: therocks]
#675671
04/20/10 08:05 PM
04/20/10 08:05 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I think he means the two wires that go from the distributor back to the MSD box.
It will be interesting to see what you find out as mine did the same thing about 3weeks ago.
Re: MSD 6AL test
[Re: Red Express]
#675673
04/21/10 07:45 AM
04/21/10 07:45 AM
therocks
Niles , Ohio
Ill try that.That or Ill have my kid take his coil off and try it.Rocky
Chrysler Firepower
Re: MSD 6AL test
[Re: therocks]
#675674
04/21/10 10:23 AM
04/21/10 10:23 AM
therocks
Niles , Ohio
I changed coils and jumped the 2 wires.No spark.I also checked the wiring and have 12 V to the 2 that should and also good ground.I guess the box is bad.What does MSD charge to redo them?I ordered a new box where my kid works.Should be here today.Rocky
Chrysler Firepower
Re: MSD 6AL test
[Re: Red Express]
#675675
04/21/10 11:16 AM
04/21/10 11:16 AM
therocks
Niles , Ohio
Just started to take the old one out.I tapped the box and now it runs.Real strange.I guess Ill still get the new one and have a spare.Rocky
Chrysler Firepower
Re: MSD 6AL test
[Re: 52savoy]
#675677
04/22/10 08:08 AM
04/22/10 08:08 AM
therocks
Niles , Ohio
Mines a 65 Belvedere.I gusy mounted mine between the right fender and rad.My wiring is pretty hacked.I left the ballast in and run it.It can be run with or without the ballast so it was easy to just leave it.Just carry a spare and its been in for years with no problems.Rocky
Chrysler Firepower
