best way to block heat crossover #675501
04/20/10 10:11 AM
04/20/10 10:11 AM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
have a all stock 69 383hp with the iron dp intake maifold and am asking what is the best way to block the heat crossover to keep the iron manifold cooler??
Re: best way to block heat crossover [Re: ngpSatellite] #675502
04/20/10 10:40 AM
04/20/10 10:40 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: best way to block heat crossover [Re: bee1971] #675503
04/20/10 11:46 AM
04/20/10 11:46 AM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Balled up tin foil does the job, too!
Re: best way to block heat crossover [Re: rabid scott] #675504
04/20/10 11:49 AM
04/20/10 11:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
eddelbrock heads or a manifold with no crossover
