06 caravan power side door problem
#675379
04/20/10 07:56 AM
04/20/10 07:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Hey everybody, especially chrysler techs,
our '06 caravan has developed a little problem. the driver's side power sliding door, when you hit the button, opens up about 3" and then stops, and you have to manually open it the rest of the way. if it's all the way open, it closes to about the same spot and then stops. manually, it works fine. any ideas on where to start? I'm assuming there's some sort of sensor that is out of adjustment?
any help is appreciated.
Re: 06 caravan power side door problem
[Re: Todd]
#675382
04/20/10 09:58 AM
04/20/10 09:58 AM
patrick
Grand Haven, MI
is that the harness that's in the plastic chain at the bottom of the door?
[Re: Todd]
#675385
04/20/10 04:28 PM
04/20/10 04:28 PM
patrick
Grand Haven, MI
nope, door opens and closes smoothly.
would happen intermittently, but with greater frequency for the past few weeks. this weekend I hit some of the moving parts with some spray lube, it worked the first time, but no other time after that.
my dad has an '03 FSM and he looked it up later that afternoon and it said not to use any lube, so I cleaned it all off with some CRC electronic cleaner, still stopped after about 3". He said that the manual says the body computer may throw a code to help diagnose it, but I don't have access to a scantool, and wasn't sure if the free autozone scan would pick up codes from the body computer.
