flipping front hanger on a body? #675351
04/20/10 06:12 AM
04/20/10 06:12 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
want to lower the rear on the duster a bit as ss springs jack her up a bit more than i like.will the front hanger bolt in after being inverted?or will it need to modified?and any idea how much it will lower it?1-1 1/2 " and anything else i should be aware of besides pinion angle
Re: flipping front hanger on a body? [Re: mcmopars] #675352
04/20/10 10:17 AM
04/20/10 10:17 AM
insert the bolt from the outside and you'll be good. Not sure on the amt of gain. EDIT w more thought I dont think you'll net 1&1/2"
Re: flipping front hanger on a body? [Re: mcmopars] #675353
04/20/10 10:39 AM
04/20/10 10:39 AM
AndyF Offline
AndyF  Offline
The bolt pattern is different from top to bottom so you can't just flip the hangers over.
Buy new hangers from Mancini Racing or Firm Feel. The new hangers come with a second eye bolt location.
Re: flipping front hanger on a body? [Re: AndyF] #675354
04/20/10 05:09 PM
04/20/10 05:09 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
any idea of what i would gain?
Re: flipping front hanger on a body? [Re: mcmopars] #675355
04/20/10 05:11 PM
04/20/10 05:11 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
just looked at firm feel,lowers 1 ".thanks
Re: flipping front hanger on a body? [Re: mcmopars] #675356
04/20/10 06:12 PM
04/20/10 06:12 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Flip the hangers.....a little die grinder makers quick work of the bolt hole issue. Dropped mine all of an inch Be prepared to check/change pinion angle!Mine have been flipped for years with no problems!
Re: flipping front hanger on a body? [Re: Dcuda69] #675357
04/20/10 08:10 PM
04/20/10 08:10 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Dropped my car more than one inch as you can see in this picture I put together. The top two are obviously before I flipped the front mounts.
