Re: 1970 Duster 340 Fuseblock pics
[Re: Dart 340]
#67531
06/05/08 12:35 PM
06/05/08 12:35 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
I can take one of mine, but won't be until tonight.
Which fuse is blown?
The car was in pieces when I bought it and had been sitting since '79. the fusebox stenciling is pretty much non-existent and no fuses were in it.
I don't know if std. fuse block is different from the rally gauge fuse block though. Picture or simple text from left to right etc. showing what is what and what amp fuse to put in would suffice. thanks!
[Re: RobX4406]
#67533
06/05/08 12:57 PM
06/05/08 12:57 PM
W5Duster436
Indiana
I looked in the cars and don't have one loose here. I have to go to storage and think I have one out of the car. I'll get a crappy pic of it later today.
Rob at $4 a gallon don't go make a special trip..
[Re: W5Duster436]
#67534
06/05/08 01:29 PM
06/05/08 01:29 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
No special trip. I got yelled at the other day because there are two huge boxes in the living room. Those have to go to storage anyways.
Send me the medallion dimensions again. I've been hammered with stuff recently.
[Re: RobX4406]
#67535
06/05/08 02:10 PM
06/05/08 02:10 PM
W5Duster436
Indiana
Seemed like they were about 3/8" wide on the ends and just slightly wider in the middle and about 2" tall. I had someone send me a set from a roadrunner that were the same but about 1/2" taller and I already sent them to the upholstery shop. I have about 3 weeks though so if you have them let me know asap and I can get them to the upholstery shop.
I'll have a look at my post and see if I put dimensions in there.
[Re: 70Duster440]
#67537
06/05/08 07:49 PM
06/05/08 07:49 PM
W5Duster436
Indiana
My '70 Duster block is laid out like this - starting from the end where the harness enters the block:
3A INST LPS 20A TAIL LP C-LTR 20A DOME-STOP E/FLASH 20A RADIO B/UP 20A A/C HEAT 20A ACC ACC (Empty, not used)
Also attached a diagram just for grins.
So looking at the fuse block from the front the 3A goes in the far left slot? Thanks!
