727 Valve Body Questions,HELP ASAP !! #675189
04/19/10 10:21 PM
04/19/10 10:21 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I need some advise on a 727. I am working with a 67 Hemi GTX that has been sitting for about 10 years. The transmission was like new when parked. Now it wants to hunt for a gear and sounds like it is slipping. I feel sure it is in the valve body. I have to have this car drivable tomorrow by 3 PM and will only have a few hours to get it taken care of. Any tips on pulling the valve body, and what I should be looking for?
Dan.
Re: 727 Valve Body Questions,HELP ASAP !! [Re: mopar4ya] #675190
04/19/10 10:34 PM
04/19/10 10:34 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
hunt for a gear ?
Re: 727 Valve Body Questions,HELP ASAP !! [Re: dOc !] #675191
04/19/10 10:40 PM
04/19/10 10:40 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Yes, when you put it in drive and take off it feels like it is shifting up and down between 2 gears...like it is hunting for one. The engine RPM is to high for the speed of the car, so it is slipping also.
Dan.
Re: 727 Valve Body Questions,HELP ASAP !! [Re: mopar4ya] #675192
04/19/10 10:44 PM
04/19/10 10:44 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
At what speed is it "hunting" ? .. is it slipping at all speeds? ... from a dead stop ?
Re: 727 Valve Body Questions,HELP ASAP !! [Re: dOc !] #675193
04/19/10 11:00 PM
04/19/10 11:00 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Yes, seems to be from a dead stop. I moved the car a couple of blocks, so maybe 25-30 MPH and it was slipping. Also up, down shifting and I didn't want to push to hard on it and burn the clutches. Even if you put it in low, it don't feel like it is in low and still sounds like it is slipping.
Dan.
Re: 727 Valve Body Questions,HELP ASAP !! [Re: mopar4ya] #675194
04/19/10 11:04 PM
04/19/10 11:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
what does the fluid look like? ... how about the level also?
Re: 727 Valve Body Questions,HELP ASAP !! [Re: dOc !] #675195
04/19/10 11:10 PM
04/19/10 11:10 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Fluid is starting to get dark, so I know it is slipping.
Dan.
Re: 727 Valve Body Questions,HELP ASAP !! [Re: mopar4ya] #675196
04/19/10 11:20 PM
04/19/10 11:20 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
level ? .. what does it smell like ?
Re: 727 Valve Body Questions,HELP ASAP !! [Re: dOc !] #675197
04/19/10 11:35 PM
04/19/10 11:35 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
OFF to bed ferr me .....
I would DUMP the ATF that you have in there(and get some typeF) and put on a new filter.....
Probs with the VB ? .. not likely.
Re: 727 Valve Body Questions,HELP ASAP !! [Re: dOc !] #675198
04/20/10 07:22 PM
04/20/10 07:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I know you don't want to hear this but you probably need to replace all the seals in the tranny if it's loosing pressure like that...Seems you can let a fresh trans sit indefinitely but once you run it and then sit unused the seals become brittle and don't seal well after extended periods of time...Sometimes you get lucky and sometimes you don't....Don't run it too much like that or you'll smoke it...
