Re: No antifreeze in the car at the dragstrip!
[Re: WILD BILL]
#675038
04/19/10 07:20 PM
04/19/10 07:20 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I drain mine after every event . Never store an engine with water in it. Or antifreeze for that matter.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Mopar Racer]
#675040
04/19/10 07:22 PM
04/19/10 07:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Water Wetter... or you can use water soluble oil but you need some lube in there for the pump instead of straight water
[Re: sg66mopar]
#675043
04/19/10 09:08 PM
04/19/10 09:08 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Justice Brothers makes a Cooling System Protector and a Radiator Cooler. I used the Protector for years, it does a good job of preventing rust.
[Re: CMcAllister]
#675044
04/19/10 09:13 PM
04/19/10 09:13 PM
after ruining a $25,000 motor a few years back running only water in november. it was 67 degrees that day that night it dropped to 10 degrees and cracked my block, ruined my motor, i'll run a little antifreeze all year long.just to play it safe.
Post deleted by Defbob
[Re: '72CudaRacer]
#675046
04/19/10 09:37 PM
04/19/10 09:37 PM
#675047
04/19/10 09:41 PM
04/19/10 09:41 PM
MR_P_BODY
Thats what they make light bulbs for
#675050
04/20/10 09:34 AM
04/20/10 09:34 AM
Posts: 8,165 Left Coast
BobR
Left Coast
EVANS COOLANT DEBATABLE IF LEGAL
I use that in everything as well.
[Re: MR_P_BODY]
#675051
04/20/10 10:30 AM
04/20/10 10:30 AM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
I have always wondered about water pump lube? What does it lubricate? Isn't the bearing sealed?
[Re: cl440]
#675054
04/20/10 11:16 AM
04/20/10 11:16 AM
MR_P_BODY
I thought the same thing... but when I built 1 of my engines with a electric pump I didnt have anything but water in it... first day at the track the pump seized ... was told to run the WW for lube... put it in and turned the pump with a allen wrench to break it free and havent had a problem since
[Re: MR_P_BODY]
#675055
04/20/10 11:31 AM
04/20/10 11:31 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
x2 on the de-ionized de electrolized reverse osmosis water.. or in a pinch distilled water. w/ Water wetter. much lest issue with rust and the galvanic/electrolosis corrosion of steel block, copper head gasket and aluminum head... fwiw cheapst
ps you guys with "well" wter like my buddy in Ohio..keep that out of your block..that stuff is rust maker on steroids...
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
