Page 2 of 3 1 2 3
Re: B Body Fuel Sending Unit [Re: dobie] #674863
04/20/10 01:40 PM
04/20/10 01:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The blue wire goes to ground not power... The reason you only want to do this briefly is there is no 10 ohm resistor so if you leave the key on it will smoke the gauge...
To ise the resistors a couple wires with alligator clips works well...
Re: B Body Fuel Sending Unit [Re: 1_WILD_RT] #674864
04/20/10 01:43 PM
04/20/10 01:43 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just hook a test light to the hot wire at the sender.It should nlink.If it dosent either the V limiter is bad or break in the wire to the sender.Rocky
Chrysler Firepower
Re: B Body Fuel Sending Unit [Re: therocks] #674865
04/20/10 04:05 PM
04/20/10 04:05 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Well, thanks guys for all of the help. I basically give up though. Nothing I try works, so with my luck, it's the gauge itself. At this point, I refuse to tear everything apart to replace the fuel gauge. The easiest thing to do is to try another sender, but it's a crap shoot at best. Plus, once I buy it and install it, it's mine, and I have no need for another sender at this point. Besides, I always seem to spill about 2 gallons of gas trying to take it out. My little siphon that I have is terrible, and I can never get enough gas out before removing the sender. Therefore, I give up! Besides, the car runs fine, and it's nice to take it for a little spin when I want too, and not have things torn apart. Later this year I'll buy a 2 5/8 fuel gauge from Summit, slap it in, and hopefully fix (or bypass) the original problem. My car's a driver, so I'm not going for originality.
1968 Plymouth Road Runner 383 4 speed
Re: B Body Fuel Sending Unit [Re: dobie] #674866
04/20/10 09:52 PM
04/20/10 09:52 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Ok, I got pissed again, and had to do something. I jerked out the sending unit and tried it out of the tank. Sure enough, when the float arm is all the way up, the gauge only reads 1/2.
Tomorrow I'll be trying another sending unit, so I should know tomorrow if it's either the gauge or the sender.
Re: B Body Fuel Sending Unit [Re: dobie] #674867
04/20/10 09:57 PM
04/20/10 09:57 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Check out the sending unit from Dixie restoration products the price is good and it made by the same vendor that made them for Chrysler. www.dixierestorationparts.com
Re: B Body Fuel Sending Unit [Re: Y3 70 BEE] #674868
04/20/10 10:01 PM
04/20/10 10:01 PM
NJ
440challenger Offline
NJ
Had a problem like that. Ended up being the gauge. cant you ground the sending unit wire and see if the gaue reads full to make sure the gauge works?
Re: B Body Fuel Sending Unit [Re: 440challenger] #674869
04/20/10 10:14 PM
04/20/10 10:14 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
Believe me, I'll be the first to admit, I'm an idiot in these matters. I tried that earlier and never could get the needle to move one bit. Even following the advice here, I couldn't get it. I figured pulling the whole darn thing out was my only option.
Re: B Body Fuel Sending Unit [Re: dobie] #674870
04/20/10 10:18 PM
04/20/10 10:18 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I was talking to Gentry (1 of the owners) @ Auto Instrument and here's how he explained to check all of the gauges on a Mopar cluster....I should say it was my Ralley cluster..Your gauges all read the same E 1/2 F
73 27 10 ohm
thats the scale for all the gauges,oil temp,etc.. they all read the same Ohms the best way is to get the tank empty and pull the sender wire and put you meter on the term.,turn the key on and it should read 73 ohms,then add gas to 1/2 and you should be at 27 ohms,then fill it and you should have 10 ohms.This will be the same for oil press.,temp. Like first start(cold engine) up oil gauge should read 10 ohms(high pressure)and 73 ohms for temp.(cold engine)....and so on until you get the right readings, THE BIGGEST problem are mis-matched senders to gauge cluster...but here's a way to check to sender vs.gauge....I hope this helps you can PM if you need more info....
Re: B Body Fuel Sending Unit [Re: Hemiruss] #674871
04/20/10 10:26 PM
04/20/10 10:26 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
That's interesting. I'll have to try that with a helper in the morning.
Re: B Body Fuel Sending Unit [Re: dobie] #674872
04/20/10 10:35 PM
04/20/10 10:35 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
All 3 except Alt.can be done this way,I'm going to do mine Sat.since the dash rebuild came back.So good luck and I hope you find the problem..
Re: B Body Fuel Sending Unit [Re: Hemiruss] #674873
04/21/10 05:58 PM
04/21/10 05:58 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
I tried another sending unit this morning. Sure enough, both senders read the same on the gauge. At full stop, the gauge was only 3/4, then it would drop drastically. At 3/4 on the sender the gauge was at below 1/2 already. 1/2 on the sender was between E and 1/4. So, I'm of the opinion now that it's for sure the gauge.
That said, I went to Summit earlier and picked up an Auto Meter fuel gauge and plan to install it Friday morning. I'm definitely not spending 3 hrs to rip out my dash and go from there.
Re: B Body Fuel Sending Unit [Re: dobie] #674874
04/21/10 08:03 PM
04/21/10 08:03 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Hope you have better luck than I did. I tried the exact same thing and my Auto Meter gauge read same as dash gauge. Just trying to live with the dash gauge for now. Been watching this thread as my problem sounds exactly like yours. Again good luck,sure wish I could get mine reading correct.
Re: B Body Fuel Sending Unit [Re: pushbutton] #674875
04/21/10 08:12 PM
04/21/10 08:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: B Body Fuel Sending Unit [Re: pushbutton] #674876
04/21/10 10:57 PM
04/21/10 10:57 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
You're kidding?? Great. My luck too I'm sure.
Re: B Body Fuel Sending Unit [Re: dobie] #674877
04/23/10 02:50 PM
04/23/10 02:50 PM
Ohio
dobie Offline OP
dobie  Offline OP
Ohio
New fuel gauge is in, and nothing solved.
I give up.
Thanks for the help though guys.
Re: B Body Fuel Sending Unit [Re: dobie] #674878
04/23/10 04:15 PM
04/23/10 04:15 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I give up.
No offense, but I don't understand your mentality. If you let something like a silly sending unit beat you so easily, I can't imagine what other things in life have passed you by. Get out there, grab it by the horns and FIX THAT CAR!
Re: B Body Fuel Sending Unit [Re: dobie] #674879
04/25/10 04:09 AM
04/25/10 04:09 AM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
Ok, I just got my Sending unit and it didnt work like it should so I decided to take it apart and see what is wrong with it. First I had to bend back the three tabs that hold the sending unit together.
Re: B Body Fuel Sending Unit [Re: WilliamHall] #674880
04/25/10 04:11 AM
04/25/10 04:11 AM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
You can see the resistor portion which a flexible copper tab rides against as the floating arm moves. Here is a picture of the resistor portion which is partially colored yellow. I am sure each little section equates to 1 ohm or so.
Re: B Body Fuel Sending Unit [Re: WilliamHall] #674881
04/25/10 04:15 AM
04/25/10 04:15 AM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
And finally the solution. Just bend the copper tab back so that it makes a harder contact whith resistor part as the swinging float moves.
Then put it back together and rebend the 3 metal tabs. Hope this helps.
Re: B Body Fuel Sending Unit [Re: WilliamHall] #674882
04/25/10 07:57 AM
04/25/10 07:57 AM
Australia
charger RTSE Offline
Australia
I adjusted mine and got it nearly perfect.
The trick was to bend the float arm where it comes out of the sender so that when the float is fully up it will actually go up further on the mechanism inside do not bend the float arm on the end. I also bent the top stop back so to give the arm more travel.I hope this makes sence i took mine in and out three times before i worked out how to get it right.My original guage used to read over full. The new one reads just under full when i put the repro one in it first read 3/4 full.If i took it out again i could probably get it spot on.
Page 2 of 3 1 2 3
