Re: B Body Fuel Sending Unit
[Re: 1_WILD_RT]
#674864
04/20/10 01:43 PM
04/20/10 01:43 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
Just hook a test light to the hot wire at the sender.It should nlink.If it dosent either the V limiter is bad or break in the wire to the sender.Rocky
Chrysler Firepower
[Re: therocks]
#674865
04/20/10 04:05 PM
04/20/10 04:05 PM
Posts: 1,032 Ohio
dobie
Ohio
Well, thanks guys for all of the help. I basically give up though. Nothing I try works, so with my luck, it's the gauge itself. At this point, I refuse to tear everything apart to replace the fuel gauge. The easiest thing to do is to try another sender, but it's a crap shoot at best. Plus, once I buy it and install it, it's mine, and I have no need for another sender at this point. Besides, I always seem to spill about 2 gallons of gas trying to take it out. My little siphon that I have is terrible, and I can never get enough gas out before removing the sender. Therefore, I give up! Besides, the car runs fine, and it's nice to take it for a little spin when I want too, and not have things torn apart. Later this year I'll buy a 2 5/8 fuel gauge from Summit, slap it in, and hopefully fix (or bypass) the original problem. My car's a driver, so I'm not going for originality.
1968 Plymouth Road Runner
383 4 speed
[Re: dobie]
#674866
04/20/10 09:52 PM
04/20/10 09:52 PM
Posts: 1,032 Ohio
dobie
Ohio
Ok, I got pissed again, and had to do something. I jerked out the sending unit and tried it out of the tank. Sure enough, when the float arm is all the way up, the gauge only reads 1/2. Tomorrow I'll be trying another sending unit, so I should know tomorrow if it's either the gauge or the sender.
383 4 speed
[Re: Hemiruss]
#674871
04/20/10 10:26 PM
04/20/10 10:26 PM
Posts: 1,032 Ohio
dobie
Ohio
That's interesting. I'll have to try that with a helper in the morning.
383 4 speed
[Re: Hemiruss]
#674873
04/21/10 05:58 PM
04/21/10 05:58 PM
Posts: 1,032 Ohio
dobie
Ohio
I tried another sending unit this morning. Sure enough, both senders read the same on the gauge. At full stop, the gauge was only 3/4, then it would drop drastically. At 3/4 on the sender the gauge was at below 1/2 already. 1/2 on the sender was between E and 1/4. So, I'm of the opinion now that it's for sure the gauge. That said, I went to Summit earlier and picked up an Auto Meter fuel gauge and plan to install it Friday morning. I'm definitely not spending 3 hrs to rip out my dash and go from there.
383 4 speed
[Re: dobie]
#674877
04/23/10 02:50 PM
04/23/10 02:50 PM
Posts: 1,032 Ohio
dobie
Ohio
New fuel gauge is in, and nothing solved.
I give up.
Thanks for the help though guys.
383 4 speed
[Re: dobie]
#674878
04/23/10 04:15 PM
04/23/10 04:15 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
I give up.
No offense, but I don't understand your mentality. If you let something like a silly sending unit beat you so easily, I can't imagine what other things in life have passed you by. Get out there, grab it by the horns and FIX THAT CAR!
