What is a good ignition coil to buy? #67462
06/04/08 02:20 PM
06/04/08 02:20 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
Since I'm replacing most of the ignition system, it only makes sense to go with a new coil too, as mine is an unknown age unit. What is a good coil to buy? I'd really just like one I can run without a ballast resistor. Any suggestions?
Re: What is a good ignition coil to buy? [Re: DaytonaTurbo] #67463
06/04/08 02:27 PM
06/04/08 02:27 PM
Kirkland, Washington
Pacnorthcuda Offline
the epoxy filled MSD Blaster vibration proof is a great choice. The "e-core" types are good too. Oil-filled is old school, but works.
Re: What is a good ignition coil to buy? [Re: Pacnorthcuda] #67464
06/06/08 01:31 PM
06/06/08 01:31 PM
Manitoba, Canada
Manitoba, Canada
Re: What is a good ignition coil to buy? [Re: DaytonaTurbo] #67465
06/06/08 01:37 PM
06/06/08 01:37 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The FBO coil can handle 8.5-11.0 volts .
Re: What is a good ignition coil to buy? [Re: YO7_A66] #67466
06/06/08 01:45 PM
06/06/08 01:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
since I rencently learnt that MP coil is the same MSD Master Blaster 2, would go for MP one ( if you want stock kind coil, but high performance output )
If not, then some MSD "dry" ( not internal oil ) kind
Re: What is a good ignition coil to buy? [Re: Pacnorthcuda] #67467
06/06/08 02:04 PM
06/06/08 02:04 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
As for FBO, I tried two of those, both didn't work worth a darn. This was before I installed the MSD unit, back when I was running a stock dizzy.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
