1990 speedo #674468
04/19/10 09:37 AM
04/19/10 09:37 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Can't get my speedo working on my 90 dodge truck. Replaced sensor and speedo with known good units, gear in trans functioning well, changed engine computer as well....what gives anyone?
If I hafta come in and getchya.......I'm gonna getchya!
Re: 1990 speedo [Re: Gt383] #674469
04/19/10 10:08 AM
04/19/10 10:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
They get goofy after 130-150k miles on the trucks I've had. Make sure you check all the connections, it helps to have a good wiring diagram. You will see an orange wire in a large harness connector under hood near trans dipstick tube, that IIRC is the signal wire from trans to speedo head. It goes other places too, so diagram is a must.
Re: 1990 speedo [Re: buildanother] #674470
04/19/10 10:22 AM
04/19/10 10:22 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
so it should not have power, how does it get the signal is it magnetic or what? I have traced the wires and ur right its orange with a white tracer.
Re: 1990 speedo [Re: Gt383] #674471
04/19/10 11:03 AM
04/19/10 11:03 AM
chicagoland,usa
chicagoland,usa
I can't recall if the speed sensor is pm generator or not.
Re: 1990 speedo [Re: buildanother] #674472
04/19/10 11:58 AM
04/19/10 11:58 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
when everything seems to check out and doesnt work arrgghh
