heat riser
#674335
04/18/10 11:33 PM
04/18/10 11:33 PM
340dart4spd
Parts Problem
Parts Problem
Re: heat riser
[Re: NachoRT74]
#674337
04/19/10 10:33 AM
04/19/10 10:33 AM
340dart4spd
Parts Problem
Parts Problem
Re: heat riser
[Re: 340dart4spd ]
#674338
04/19/10 10:57 AM
04/19/10 10:57 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
thats the same vendor I PM you last night, but on his ebay sales instead the yahoo store. I'm searching the kit I have to show you here is the apparently diff between both kits ( earliers and laters legend on pics NOS MoPar 1968-70 340 Exhaust Manifold HeatRiser Package
This is an NOS MoPar exhaust manifold heat riser repair package that fits 1968 - 1970 340 models only with manifold casting #2863549. Part number is 3004574.
This includes all the correct parts including the 2-1/4" diameter valve. Don't be mislead by cheap "one-size-fits-all" 318 kits that other companies will try to sell you. This is the real deal with instructions. This package fits 1968-70 340 only! For use only on manifolds with casting number 2863549. This is the only correct package for these unique hi-flow manifolds.
1971-93 318/360 kit, part number 3683947. Most of the components including the crucial ones are different. The early 340 hi-flow manifold uses a 2-1/4" diameter valve while the later 318/360 manifold uses a smaller 1-7/8" diameter valve.
Re: heat riser
[Re: NachoRT74]
#674339
04/19/10 11:06 AM
04/19/10 11:06 AM
NachoRT74
Valencia, España
found an old pic I have took long time ago of the kit I have ( attachment ). Is the one I can sell cheap. and confirmed the PN on it is the lates one 3683947 missed the spring what looks like an arch. You can compare kits on pic and note whats the one missed... note with this pic:
