SS Spring Mounts/Pinion angle #674259
04/18/10 10:36 PM
04/18/10 10:36 PM
NE
moparpoolman Offline OP
NE
Hi guys, With the SS spring mounts there are 2 sets of holes for the spring to mount to. I used the top hole to keep the car as low as possible. Is it OK to use either hole? Now my pinion angle is way off, 5 degrees up. I was told I should have 5 Degrees down. Would the lower/bottom hole on the mount change my pinion angle or will I need shims???
Re: SS Spring Mounts/Pinion angle [Re: moparpoolman] #674260
04/18/10 11:44 PM
04/18/10 11:44 PM
You're speaking of the front shackle w a pair of horizontle holes on each side of shackle then another pair below them? Yes shims will be needed as swapping holes to raise/lower the front of the spring will not effect a 10 deg change.
Re: SS Spring Mounts/Pinion angle [Re: RapidRobert] #674261
04/19/10 01:10 AM
04/19/10 01:10 AM
Wichita,ks.
jst19600 Offline
jst19600  Offline
Wichita,ks.
I think i had to put a 6 degree shim in mine.With that thick of a shim i had to also get a longer index/alignment dowel pin.I actually used one off a for falcon which is alot longer that a stock mopar.
Re: SS Spring Mounts/Pinion angle [Re: jst19600] #674262
04/19/10 05:02 AM
04/19/10 05:02 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
When I put my springs in the upper hole I had the same problem. I had to use a 6* shim. Shop around for shims. I used a procomp shim from 4wheel parts. It is 5/8" on the fat end to 0 on the point. Fits the pin in the springs fine and I have about 3.5* down on my pinion now.
