Re: carb choice
[Re: EASY]
#674097
04/19/10 01:20 AM
04/19/10 01:20 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Define "mild". For a street car with a hydraulic flat tappet cam and moderate gearing, You may be happier with a Vacuum Secondary 750.
Re: carb choice
[Re: EASY]
#674100
04/19/10 06:29 AM
04/19/10 06:29 AM
Posts: 5,446 Indiana
YO7_A66
Indiana
Easy, I run a QF SS-750-AN (DP)on my mild 340. It has annular boosters which QF says it's actual cfm is 735. It has adjustable secondary mechanical linkage which you can delay either 40% or 60% with just a linkage swap to help tune the secondaries. The annular boosters gives better throttle response versus my other two DP carbs with downleg boosters. Call the guys at QF and ask them for their suggestions. You might want to add some more info about your combo unless your already sutup for a DP.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: carb choice
[Re: YO7_A66]
#674101
04/19/10 07:19 AM
04/19/10 07:19 AM
Posts: 520 New Zealand
nz383man
New Zealand
Annular boosters can make a carb that is a bit big work well down low without the restriction of a small carb at the top end.
Converting my AVS to annular boosters & a few other minor mods gave me .3 sec & the same economy with 3.91 gears that I used to get with 3.23's
Re: carb choice
[Re: RapidRobert]
#674102
04/19/10 08:55 AM
04/19/10 08:55 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
"mild 383" that'd be my suggestion
Unless it is a 4 speed?
Re: carb choice
[Re: EASY]
#674104
04/19/10 05:33 PM
04/19/10 05:33 PM
Posts: 84 NC
Badfish67
NC
For the price your going to pay for a Quick Fuel you can call Patrick at Pro Systems and have him build you a carb that is custom made for your combination.
1967 Barracuda
360ci/727
9.723ET @139.44mph
