742 case pinion help #674014
04/18/10 08:18 PM
04/18/10 08:18 PM
NJ
440challenger Offline OP
NJ
pinion nut on my 742 case 3.91 suregrip came loose. Now when i tighten the pionion nut i can not spin the wheels . The 742 uses shims, so shouldnt i be able to tighten that pretty tight with an air gun and it still spin freely?
Re: 742 case pinion help [Re: 440challenger] #674015
04/18/10 08:39 PM
04/18/10 08:39 PM
scratchnfotraction Offline
i just replaced the pinion seal on my 742-3.23 open
i could turn minefreely
well it did have all the drag of the rear axles and tires but I could turn it by hand fairly ez
Re: 742 case pinion help [Re: scratchnfotraction] #674016
04/18/10 10:44 PM
04/18/10 10:44 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Are trying to turn the tires or the yoke? If you have a good sure grip turning just the tires by hand can take some effort.
Re: 742 case pinion help [Re: 440challenger] #674017
04/18/10 11:30 PM
04/18/10 11:30 PM
There's a major problem. The chunk is going to have to come out unfortunatly
Re: 742 case pinion help [Re: RapidRobert] #674018
04/19/10 07:37 AM
04/19/10 07:37 AM
NJ
NJ
I was turning just the tires. The suregrip is deffiently good as the two black stripes i left for 200ft after i tighten the nut proved
So you think it has to come apart? I've had this unit in my car for 5 years and just recently the nut came loose and i had a humming noise on decell.
Re: 742 case pinion help [Re: 440challenger] #674019
04/19/10 08:47 AM
04/19/10 08:47 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
To fix it right it needs to come out.
The preload on the pinion bearings has to be set
without the posi in the case. It seems like you
need another shim behind the front bearing.
You need to inspect the ring-pinion and pinion
bearings. When you tighten the yoke, do it in steps-while turning the pinion, DON'T use an
air gun.
