E Body oil pan #673956
04/18/10 05:58 PM
04/18/10 05:58 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Quick question, is the oil pan for a 70 and 71 340 Cuda #294? Also, were there any other pan used?
Thanks in advance
Re: E Body oil pan [Re: 5carguy] #673957
04/18/10 06:28 PM
04/18/10 06:28 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
As per galins book that is the only one.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: E Body oil pan [Re: stickman] #673958
04/19/10 08:44 AM
04/19/10 08:44 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
How can you tell if it's a 294 pan,is the number stamped on the pan?
