Alternator Swap #673919
04/18/10 05:37 PM
04/18/10 05:37 PM
Ca
speedy515 Offline OP
Ca
I'm running the stock alternator on a Small Block 360. It makes 65amps, I think.
I've been looking around and seeing alternators 1/2 the size and making 120+ Amps.
Can I simply swap mine for one of these? If not what needs to take place to make this work in a 70 Challenger with original wiring.
Speedy515
Re: Alternator Swap [Re: speedy515] #673920
04/18/10 05:59 PM
04/18/10 05:59 PM
scratchnfotraction Offline
use an external regulated mini ALT. and it wires up and uses the stock VR
I did ths on my 85 truck with 440 in the sig pic
you may need to bypass the amp guage and you may need a solid state VR if it has the older mech points VR
should be able to flip it over(ear/lugs) and use the stock brackets,may need to make the lower longer
there is a bracket templat in the tech archives you can print out and make a metal bracket for the lower one on SB
you do have to cut the slip terms off and use eyeloops with the newer alt
there are also internal regulated alt that have 1 wire hook up and some other wire mods that can be used also
Re: Alternator Swap [Re: scratchnfotraction] #673921
04/18/10 06:07 PM
04/18/10 06:07 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
What does a external regulated mini starter have to do with his question about changing alternator?
Re: Alternator Swap [Re: scratchnfotraction] #673922
04/18/10 06:11 PM
04/18/10 06:11 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
If you know your Mopar alternators find an older one that puts out 90 Amps.Thery made these for quite awhile. I have a few of them. It looks like your original one but has a 1/4 inch stator instead of a 1/2" looking stator. These put out a lot with out having to change anything. They are not hard to find just have to know what you are looking for.
Re: Alternator Swap [Re: gtx69] #673923
04/18/10 06:12 PM
04/18/10 06:12 PM
its 1/2 the size and is a bolt on swap useing the external regulated mini alt with the stock wireing and VR
thats what i read,smaller,120 amps,whats needed
what did I miss..?
Re: Alternator Swap [Re: scratchnfotraction] #673924
04/18/10 06:15 PM
04/18/10 06:15 PM
I see what you said now
I ment to type alt,not starter
yep I missed it all right
Re: Alternator Swap [Re: speedy515] #673925
04/18/10 06:21 PM
04/18/10 06:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
With original wiring, I wouldn't bother with a 120 amp alternator. Do you really NEED that much power? Unless you have heated seats, heated mirrors, heated rear window, AC, NAV system, a thumping stereo AND a high powered ignition you don't NEED 120 amps.
Don't be the exception.
Re: Alternator Swap [Re: Supercuda] #673926
04/18/10 07:09 PM
04/18/10 07:09 PM
BDW Offline
BDW  Offline
You start putting 120A through that bulkhead connector and you're asking for major trouble.
http://www.allpar.com/history/mopar/electrical.html
Re: Alternator Swap [Re: BDW] #673927
04/19/10 12:40 AM
04/19/10 12:40 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
one thing needs to be mentioned... you can get 300 amps alt if you want, but if the power demand by the car and options is "just" 60-70 amps you will only get 60-70 amps from it.
so the bulkhead weakness is not in REALLY in direct relationship with alternator output rate. Just that when an alt is able to feed the power demand to the main splice ( located just right before the ammeter coming from alt ) all the power will come from that side and never from the batt, so the load won't be shared by these two terminals ( alt and batt wires ), will run by just the alternator terminal at bulkhead. thats why the upgrade on wiring/terminals is needed.
the advantage of bigger output alts is not more than the iddle charge/feed capacity, more efficient than basic old stock alts, and not really the TOTAL output rate from alt.
however, old BIG Mopar alts are in mostly of cases, enough for a plug and play upgrade... these alts were available since 75/76 years on 78 amps rate. In MOSTLY of cases, with stock equipment or just some "minor" upgrades ( halogens for example ) is more than enough even with AC.
Power windows and similar stuff being just work OCASIONALLY doesn't need to enter on consumption play since won't matter if power is being succked from batt on that moment. Alt will recharge inmediatly that once power window is set.
Honestly the IMPORTANT stuff to be calculated in power consumptions are lights, Blower ( AC or Heater ) if posible at higher speed, wipers in case of a rainy day and Radio. These are the onbly options you mostly could keep WORKING and demanding constant power from alt. Rest are not more than small peaks consumptions ( dome, turning, brakes, lighter ).
Ignition system is allways covered enough by any alternator in mostly of cases, but for more exact calculation, add some amps on the play.
Then if you have some upgrades, electric gas pumps, electric fans and electric water pumps.
Price rate of these 78 amps STOCK ALTS are on $45-60, being a plug and play job if you are already on electronic regulator deal. Just some clearence of alt mounting is missed, being these alts are maybe a couple of milimeters wider, and making a tighter mounting even with block on back side of alt. Is recomenden use a slightly longer belt for it
Re: Alternator Swap [Re: NachoRT74] #673928
04/19/10 01:03 AM
04/19/10 01:03 AM
Nacho what I am gathering is a large alt is actually good to keep everything fed on that side of ammeter plus the 2 wire bypass past the bulkhead, slightly larger wiring/clean connections and a std 78 amp alt so as little current as possible has to go to/from the battery and thru the ammeter
Re: Alternator Swap [Re: RapidRobert] #673929
04/19/10 01:07 AM
04/19/10 01:07 AM
Valencia, España
Valencia, España
just exactly like that!
Re: Alternator Swap [Re: NachoRT74] #673930
04/19/10 01:10 AM
04/19/10 01:10 AM
I didn't miss anything!
Re: Alternator Swap [Re: RapidRobert] #673931
04/19/10 01:35 AM
04/19/10 01:35 AM
Valencia, España
Valencia, España
of course, also any relay upgrade being sourced from alt side will be the correct setup... source those from batt will transduce on like batt is sucking power like is discharged so the amm will read a charge from alt ( if alt is able to feed that demand of course )... false reading because mostly sure batt is not REALLY discharged and unnecesary stress on ammeter.
Re: Alternator Swap [Re: NachoRT74] #673932
04/19/10 10:11 AM
04/19/10 10:11 AM
Valencia, España
Valencia, España
forgot to say than with a FULLY DISCHARGED BATT and a POWERFULL ALT is when the ammeter become on some dangerous point since the batt will suck lot of power from alt through ammeter untill gets fully charged. Will suck allmost all the alternator output power depending on RPMs.
This moment will become in a more dangerous if you have a large reserve capacity on batt with lot of amperes... ( 700, 900 amps reserve ) due the LONG time will take to get it charged back.
That's the only point when the ammeter becomes on a REALLY weak point... also when alt comes bad and you have lot of consumption from car due the upgrades being all the power coming from batt will feed through ammeter.
but at THOSE specific moments simply this two proceedements are bad:
-Charge the batt back into the car from zero or allmost zero.
-Run the car with ALL THE EQUIPMENT turned on when alt comes bad. The consumption must be reduced at minimun.
This two moments are simply wrong proceedements even with stock alt and equipment, specially if YOU DON'T KNOW how to drive it. Charge the batt on car is not completelly bad if you make it AT IDDLE untill at least get partially the charge back, enough to ammeter get lowered the "C" reading.
Re: Alternator Swap [Re: Dartman440] #673933
04/19/10 03:10 PM
04/19/10 03:10 PM
Ca
Ca
After reading all of the above posts, I like your suggestion best. Do you have a P# or images of EXACTLY what I should be looking for?
Re: Alternator Swap [Re: speedy515] #673934
04/19/10 03:34 PM
04/19/10 03:34 PM
Valencia, España
Valencia, España
I dunno about old mopars 90 amps alts... just the lower older ones ( 40 to 55 rate ) then 60 amps, 65 amps, 78 amps and then the LEECE NEVILLE alts rated at 100 amps, but needing diff brackest setup and another stuff more. I'm not sure have read about stock 90 amps ones
if you want to know about this alt upgrade( with images ) about not more than STOCK alts, not something special or aftermarket:
http://www.moparmusclemagazine.com/techa...ator/index.html
and more readings:
http://www.dodgecharger.com/forum/index.php/topic,62772.0.html
read every link there... some nice info and good discusions
then we have aftermarkets alts 100 amps, 120 amps etc... brands like Powermaster, TuffStuff, both in stock casing and look, then we have Densos etc...
but as stated any parts shop will get you a stock powerfull slt in $50 rate
Re: Alternator Swap [Re: NachoRT74] #673935
04/19/10 03:41 PM
04/19/10 03:41 PM
Nacho is the late 70's one w the thin(er) stator the 78 amp one? (which'll be plenty for my app)
Re: Alternator Swap [Re: RapidRobert] #673936
04/19/10 03:59 PM
04/19/10 03:59 PM
Valencia, España
Valencia, España
is not thiner stator, is really same stator width, with wider windings but hidden down the housings... yes thats the one, but becarefull with the one you get, because those are in 60, 65 and 78 amps presentation. All looks the same on exterior. Mine is 60 amps and looks JUST LIKE THE 78 UNIT
Clearlyauto have the Beck/Arnley units 78 amps in $32.78+15 of the core
http://c2c.activant.com/ctoc/index.jsp?ID=gGA1KJhwDA0dBFR0MaSREf2RHG1R.AxgIX3dOTwEEXxkA
Note: DEALERS have copied the Beck/Arnley alts specs and they list the olde units one groove pulley also on 78 amps... THATS IS SIMPLY WRONG!!!
read this:
https://board.moparts.org/ubbthreads/show...rue#Post5894237
allways be sure and pay attention on every product you get, quite often dealers have listed wrong teh specs and applications ( for example Eddy IAS Shocks are listed to 64/74 B bodies and they only get up to 72 in front )
I always search for answers from dealers AND manufacturers. Get the worng unit I wish being overseas is simply wrong
The Beck/Arnley alt is just one option I'm giving due is the one a friend of mine already got and is WORKING PERFECT. In fact I recently got the same from Clearly and is waiting to be shipped from Fl to Caracas. AC Delco offers them ( in single groove presentation), BBB, and several other brands too.
Re: Alternator Swap [Re: NachoRT74] #673937
04/19/10 04:06 PM
04/19/10 04:06 PM
Valencia, España
Valencia, España
here is the 90 amps alt ?
http://cgi.ebay.com/ebaymotors/Dodge-Ply...=item53e0d17a0a
dunno, but is rated by seller... how true will be ? dunno.
Re: Alternator Swap [Re: NachoRT74] #673938
04/19/10 04:50 PM
04/19/10 04:50 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Everyone want more amps.How many amps are the 78 or 90 amps alternater at idle? That's wind we need more amps.
