Crank Sprocket Which dot lines up? Photo redone.
#673846
04/18/10 02:50 PM
04/18/10 02:50 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
There are two dots on this sprocket. It has an MP number visible on it.
Which dot is suppposed to line up to the cam sprocket dot?
Re: Crank Sprocket Which dot lines up?
[Re: GwaiiEagle]
#673847
04/18/10 03:02 PM
04/18/10 03:02 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Can't get to the photo, but use the dot that is straight up when #1 or #6 piston is at tdc. That is also when the crankshaft keyway is at the 1.30 clock position when viewing from front. (half way between 12 oclock and 3 oclock) THis is a mopar v-8, right? Found pic, DO NOT LINE THE DOT AT KEYWAY up.
[Re: buildanother]
#673849
04/18/10 03:07 PM
04/18/10 03:07 PM
RapidRobert
the one on the left that's not cut so deep, that one
[Re: buildanother]
#673852
04/18/10 04:33 PM
04/18/10 04:33 PM
RapidRobert
In the pic the "dots" appear to be pretty much at the bottom of the teeth root 3 grooves apart so if there's 24 grooves, 24 into 360 is 15, times 3 grooves is 45 & half that (going from crank to cam) is 22&1/2 cam degrees.
[Re: GwaiiEagle]
#673854
04/18/10 04:51 PM
04/18/10 04:51 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Ran funny and nosed over big time at 4500.
That's not surprising with your cam advanced 45 crank degrees!
Did the pistons and the valves meet? Any ugly noises... better check compression...
[Re: DrCharles]
#673855
04/18/10 04:54 PM
04/18/10 04:54 PM
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
Very deep valve reliefs with 484 lift.. No metallic sounds of any kind.
[Re: GwaiiEagle]
#673856
04/18/10 05:53 PM
04/18/10 05:53 PM
RapidRobert
I'm wondering why the keyway has been stamped w a dot?? No need for it that I know of and it's sure going to cause problems
