Hemi brake booster ---Help!! #67381
06/04/08 11:20 AM
06/04/08 11:20 AM
Indiana
F6F6Dodge Offline OP
Indiana
I have a 69 Charger with the Hemi Brake booster set up...I am not happy with the brake pedal position as presently set up on my car. It seems like the pedal is half way down at its resting position..this does not seem correct to me and therefore I am very uneasy about the brakes on my car---Not sure if they will work or fail when needed---can anyone help??? is there an adjustment on the pushrod or something to give me more pedal??? Thanks
Re: Hemi brake booster ---Help!! [Re: F6F6Dodge] #67382
06/04/08 12:06 PM
06/04/08 12:06 PM
CrazyD Offline
CrazyD  Offline
mine is same, sits about half the distance of the clutch pedal to the floorboard. "Back in the day" magazine photos show about the same configuration
Re: Hemi brake booster ---Help!! [Re: CrazyD] #67383
06/04/08 12:09 PM
06/04/08 12:09 PM
Indiana
Indiana
So, do you think that the position is ok where its at??
Re: Hemi brake booster ---Help!! [Re: F6F6Dodge] #67384
06/04/08 12:26 PM
06/04/08 12:26 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
The pedal with power brakes sat lower than manual brakes. It is lower than the clutch pedal.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Hemi brake booster ---Help!! [Re: doctor_mopar] #67385
06/04/08 12:38 PM
06/04/08 12:38 PM
Indiana
Indiana
Thanks for the help!!!! This is why I love MOPARTS...
