Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673703
04/18/10 06:27 PM
04/18/10 06:27 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You believe what you want .... I RTVed the gasket ON TO the pan and then lightly oiled the opposite face.
And I have been doing this LONGER than 40 years !!
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673704
04/18/10 06:28 PM
04/18/10 06:28 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The cork gaskets barely stop leaks when new. They will never come off and go back on and still seal. No way.
Re: Tranny pan wouldn't stop leaking..... [Re: scratchnfotraction] #673705
04/18/10 06:29 PM
04/18/10 06:29 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
does not matter on the cost..we are high tech with it,and keeping up with the trendy stuff
TRENDY STUFF ? ... how about a DECENT exh system on that motor pic ?
Re: Tranny pan wouldn't stop leaking..... [Re: dOoC] #673706
04/18/10 06:34 PM
04/18/10 06:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Doc, take your oldtimers medicine and join the modern world. There is no way in hell a cork gasket will last 30 years being used over and over again. You got to come up with a better story than that.
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673707
04/18/10 06:38 PM
04/18/10 06:38 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Grumpy ....just say what the cost diff is ....and I just MIGHT join that "modern-world"(of expensive gaskets) .
Re: Tranny pan wouldn't stop leaking..... [Re: dOoC] #673708
04/18/10 06:42 PM
04/18/10 06:42 PM
BDW Online content
BDW  Online Content
I paid $22 for the new gasket. Not really sure I needed it. Once it was all said and done, my leaks were coming from multiple other places. I guess it would have saved me replacing the cork style 3 times.
Moral of the story, if you think it's the pan seal, look elsewhere too.
Re: Tranny pan wouldn't stop leaking..... [Re: dOoC] #673709
04/18/10 06:44 PM
04/18/10 06:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
About $15 difference for a gasket that will seal over and over again without the need for the expense of a tube of sealer even if the pan isn't perfectly straight.
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673710
04/18/10 06:52 PM
04/18/10 06:52 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
You CHANGED this post .....
NO old-timers medicine here. But how about YOU ? ... I hear that you are ready for that rocking chair ...
The MODERN WORLD ? .. then why are you messing-around with the 60's and 70's stuff like you do? And I have not "used that gasket over and over again" like you insinuate. I have maybe pulled the pan 5/8? times over the years.
And AGAIN you avoided my simple question.
To c-guy ....22 beans ? .... I don't know what the current pricing is on cork ... but I could be convinced to use the "modern" stuff.
Re: Tranny pan wouldn't stop leaking..... [Re: stumpy] #673711
04/18/10 06:53 PM
04/18/10 06:53 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I sealed a TH350 with a flexible rubber gasket and GE Silicone 1 door and window sealer from Home Depot.
My experience with cork is that oil eventually soaks into it and it weeps out the other side. I cut a leaking low mileage cork VC gasket in half and it was soaked with oil all the way to the middle.
Re: Tranny pan wouldn't stop leaking..... [Re: Neil] #673712
04/18/10 07:06 PM
04/18/10 07:06 PM
BDW Online content
BDW  Online Content
The best thing about the reuseable gasket is you don't need to spend time scraping all that RTV off when you do change it.
I fought with a leaking differential cover, it's a major pain getting all that RTV off both surfaces.
Re: Tranny pan wouldn't stop leaking..... [Re: BDW] #673713
04/18/10 07:09 PM
04/18/10 07:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Believe me I wanted to use a mopar style reusable gasket for the th350, but couldn't find any such animal. And, yes silicone is a hassle to remove.
Re: Tranny pan wouldn't stop leaking..... [Re: Neil] #673714
04/18/10 07:13 PM
04/18/10 07:13 PM
BDW Online content
BDW  Online Content
These guys have it, wish I had found the Dana gasket before I changed it 3 times.
http://ratech.stores.yahoo.net/reaxhoga.html
Re: Tranny pan wouldn't stop leaking..... [Re: dOoC] #673715
04/18/10 07:54 PM
04/18/10 07:54 PM
scratchnfotraction Offline
OHCH! that hurt Doc
i did put a DECENT exhast on it,IMHO
i droped the rear dump log manny on the passide and use 2 center dumps and no heat flapper on the passide
with 2 nice head pipes mandrell bent 90* turns
cant get more = than that with mannys and is mucho more decent
gots the trendy mini alt and mini starter too
if you would like me to use something else..."all donations accepted"
