Heading for National Trail's this morning..RESULTS!
#673446
04/18/10 08:21 AM
04/18/10 08:21 AM
dartman366
Mt. Vernon, Ohio
..to do a little test and tunin' to see if the refreshed head's,ported Super Victor and new Quickdraw converter like each other, being followed down by Vernmotor and Kenny, a Ford buddy of mine with his wifes freshened up super-pro mustang,,should be a fun day.....detail's later today.
Re: Heading for National Trail's this morning...
[Re: VernMotor]
#673450
04/18/10 08:41 AM
04/18/10 08:41 AM
Posts: 1,049 ohio
all spooled up
ohio
[Re: all spooled up]
#673452
04/18/10 09:14 AM
04/18/10 09:14 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Never touched it
[Re: WILD BILL]
#673453
04/18/10 09:17 AM
04/18/10 09:17 AM
dartman366
Mt. Vernon, Ohio
Never touched it
but did you think about it,,,,some people do believe in karma you know.
[Re: dartman366]
#673454
04/18/10 06:14 PM
04/18/10 06:14 PM
Posts: 1,049 ohio
all spooled up
ohio
#673455
04/18/10 07:10 PM
04/18/10 07:10 PM
dartman366
Mt. Vernon, Ohio
not a bad day all in all, track prep wasn't too bad but was pretty chilly and a little bit of cross wind and a lot of street car's,,ricer's and mustang's mainly, now to the car,,first pass I ended up short shifting for some reason (first pass jitter's but ended up running a 10.21 at 129.29 with a 1.39 sixty foot came back up return road had it high and whacked the throttle and went 5200,,,,,,,,perfect! right where I had Jason at Quickdraw converter's build it. second pass was a major brainfart on my behalf, thought the shifter had moved too far back like it went into third,so i bumped it forward and went back into first didn't take long to pull it back again but the 60 foot was a 1.38,, waited in the stageing lanes for an hour and fourty five minutes while they cleaned up some Honda internals from all over the track and finally got pass three in,best of the day 10.114 at 129.92 with a 1.374 sixty foot, so it seem's the car is going to be good, I like the new converter even tho it did slow my 60's a few hundreths but Jason said it would a little but part of the reason I had one built was to drop stall to help take some violence out of the launch,,,so far so good and as far as what Terry did to the heads,,,,,well let me put it this way,,that motor has never ran that smoothly going down the track,,yep pretty good day, came home with all the pieces still where they are supposed to be.
[Re: Chad Bittle]
#673457
04/18/10 07:58 PM
04/18/10 07:58 PM
You are right Bill a ton of steet cars, vans and trucks. We made two passes and went home. Track was greasey as soon as you left the concrete, car looked like a snake going down track. Went to the Holt's T&T on Saturday and between the 30mph headwind and the cold weather and the green track we lifted two out of the three passes and spun like crazy on the third pass. I am sure you will have much more when you get the car on a good track and decent weather. poppaj
Re: Heading for National Trail's this morning..RESULTS!
[Re: dartman366]
#673459
04/18/10 09:40 PM
04/18/10 09:40 PM
Posts: 1,413 Johnstown
69dart
Johnstown
Good job guys. I'm only 8 miles away now and I didn't go up. I'm waiting patiently you can't beat Mt Vernon on Friday nite for TnT. Track is always good and almost round robin passes. I was tempted to bring the Challenger up though and make some runs in it. Jamie what did you ever find out with your engine?
[Re: max_maniac]
#673461
04/19/10 08:34 PM
04/19/10 08:34 PM
dartman366
Mt. Vernon, Ohio
Chad, I believe the rocker problem is solved now that the pad's on the head's are now the same height and a little more time and patience was used in setting it up. Russ, only thing I ran into was not having enough adjustment with the crank trigger bracket to get the timing where I wanted,,but I fixed that tonight,,will check some thing's over and then I am ready for the Classic at Columbus, actually pretty pleased right now.
[Re: 69dart]
#673462
04/19/10 09:04 PM
04/19/10 09:04 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Good job guys.
As far as the rusty plug ? Nothing. clean that cy out. put other plug in it.. ran it.. let it sit 3 days and never seen anything again ??
[Re: dartman366]
#673464
04/19/10 09:11 PM
04/19/10 09:11 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Good job guys.
should'a put 7 more in it tho.
[Re: dartman366]
#673465
04/20/10 12:01 AM
04/20/10 12:01 AM
Posts: 1,054 mt. vernon, oh.
aarcudaden
Dennis the Menace
Dennis the Menace
mt. vernon, oh.
Good job guys.
Hes too cheap to buy seven more
