SB Rocker Shafts - How to tighten w/ Solid lifters #673430
04/18/10 07:24 AM
04/18/10 07:24 AM
NC
Badfish67 Offline OP
NC
Need some help on what the correct way is to tighten the rocker shafts down to aluminum heads with solid roller lifters.
Thanks all
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: SB Rocker Shafts - How to tighten w/ Solid lifters [Re: Badfish67] #673431
04/18/10 09:26 AM
04/18/10 09:26 AM
The order I use is tighten all 5 finger tight to where the shaft is level (w the same distance to each saddle) then tighten center bolt 1/4 turn then the one right of center 1/4 turn then the one left of center 1/4 turn then the one far right 1/4 turn then the one far left 1/4 turn. This way regardless of where each valve is at you are drawing the shaft down horizontle and evenly.The only trick is to only go 1/4 turn each time as some will be loose and some will be under tension. I'm not grasping what the difference would be between solids/hydraulics as far as drawing the shaft down
Re: SB Rocker Shafts - How to tighten w/ Solid lifters [Re: RapidRobert] #673432
04/18/10 09:51 AM
04/18/10 09:51 AM
okla.
sam64 Offline
sam64  Offline
okla.
if you have solid lifters you better have adjustable rocker arms.
Re: SB Rocker Shafts - How to tighten w/ Solid lifters [Re: sam64] #673433
04/18/10 04:35 PM
04/18/10 04:35 PM
NC
NC
I do have adjustable rocker arms...the question that I was asking is whats the best way to tighten down the rocker arm shaft. It seems to be different with solid lifters because the push rods cant compress the lifter any.
Re: SB Rocker Shafts - How to tighten w/ Solid lifters [Re: Badfish67] #673434
04/18/10 04:39 PM
04/18/10 04:39 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Back off the adjusters,tighten the shafts,rapidrobert has that correct,and set lash.
