Re: 273 closed chamber heads good? bad?
[Re: RonaldV]
#673408
04/18/10 08:04 AM
04/18/10 08:04 AM
340dart4spd
Parts Problem
Parts Problem
I wouldn't use them.. go with the later 67 up 273 heads..It's been awhile but I am pretty sure you will have problems using them..As I recall head bolts are on a different angle on early 273 are diff....or was it head bolts?
[Re: RonaldV]
#673409
04/18/10 09:07 AM
04/18/10 09:07 AM
RapidRobert
If these are the 273 heads that dont have the oddball intake bolt angle I think they'd work excellent for a low rpm torque eng and for sure would bump the CR which is always needed. For that price are the valves new also? I'm not sure if PC type seals keep too much oil out of the guides for a daily driver and if someone confirms (or not) that that is the case they could be removed and just use umbrellas.
[Re: RapidRobert]
#673410
04/18/10 09:21 AM
04/18/10 09:21 AM
340dart4spd
Parts Problem
Parts Problem
Here is some more info
http://www.allpar.com/mopar/4bbl.html
[Re: 340dart4spd ]
#673411
04/18/10 09:30 AM
04/18/10 09:30 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The intake bolt angle isn't an issue. Even though it is at a slightly different angle. I have a Performer intake on a 65 273, no problems.
To be honest, if you had a set of 273 heads lying around (FREE) and had no money to do anything else, then they'd work on a 360. But it's kinda of like getting a new exhaust system and stepping down from a 2.5" dual exhaust to a 1 7/8" single. It'll work, but it's not ideal, nor an improvment.
[Re: Supercuda]
#673412
04/18/10 09:49 AM
04/18/10 09:49 AM
Posts: 15,487 Florida
scratchnfotraction
I have done a few stock 360 with the #302 closed chamber heas not a high rpm race engine but it will up the CR and give it lots of torque down low for a work truck or 4x4 up the exhast vale to a 1.60 and home pocket port the exhast side read the torque monster write up in the tech archives for a good base combo I do them for the torque in the work truck that do a good bit of towing/hauling
[Re: scratchnfotraction]
#673413
04/18/10 02:26 PM
04/18/10 02:26 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you want performance, I'd spend the extra $400 and buy these heads from hughes all new castings, and flow significantly better than the small port heads. get some used magnum rockers, and measure for the proper pushrods, and with a cam in in the comp XE262 size range, you'll have a motor that is probably an honest 350hp/400tq motor.
[Re: patrick]
#673414
04/18/10 03:37 PM
04/18/10 03:37 PM
Supercuda
About to go away
About to go away
up yours
I've done the 302's on a 360 thing too, nice with an M body, 2.94 gears and a stick. But it only cost me the price of a set of gaskets to do this. Was easier than trying to fix the pulled out exhaust stud threads that caused me to pull the J heads.
[Re: RonaldV]
#673418
04/18/10 10:57 PM
04/18/10 10:57 PM
340dart4spd
Parts Problem
Parts Problem
UPDATE
The valves have been upgraded to 360 valves. There has been bowel work done and porting. He did not put in hardened seats though. He says hes tried 2 different intakes on it, a torqer and RPM and it bolts on fine. He has run a 13.75 in his 63 plymouth with a mild cammed 360 with the heads. For 300 bucks, I think I might try them. The main advantage is it would up my compression.
Fish
will the larger valves even fit in the small closed chamber early 23h head??
[Re: chewy]
#673420
04/18/10 11:31 PM
04/18/10 11:31 PM
340dart4spd
Parts Problem
Parts Problem
Yup, the 360 valves would fit.
Once done, though, you cant put on a 273 without notching the top of the cylinder for clearance.
If all is true, its a good deal.
wouldnt it make more sense to just go with a 302 head..
[Re: dmerc]
#673425
04/20/10 10:01 AM
04/20/10 10:01 AM
patrick
Grand Haven, MI
if they're fresh with the 1.88 valves, I think I'd do it. for a cam in a truck, I'd use a comp XE250 or 256, or a lunati vood00 60400 or 60401
[Re: patrick]
#673426
04/20/10 10:58 AM
04/20/10 10:58 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
They will make more power than a 302 because they have a smaller chamber and better flowing ports, not to mention the 360 size valves in that set. I have ran those heads and other mopar non-hardened seat heads on modern pump gas and had no problems, these are not chevy heads witch are pretty much gauranteed to recess their seats.
